HP iPAQ 200 Enterprise Handheld Series - Manually Connecting an HP Bluetooth Keyboard
The HP iPAQ 200 Enterprise Handheld series device does not require any additional steps to use the HP iPAQ Bluetooth Foldable Keyboard (FA802AA#AC3).
Launch the Bluetooth Wizard, and then follow the on-screen instructions.
However, issues may occur with this procedure, and the keyboard may not be connected using the Bluetooth.
Details
In such cases, try using the following steps to manually connect the HP iPAQ Bluetooth Keyboard to the iPAQ.
  1. Install the keyboard drivers that come with the HP iPAQ Bluetooth Keyboard. For more information, refer to the documentation that came with the HP iPAQ Bluetooth Keyboard.
  2. Make sure that the device's Bluetooth is turned on.
  3. Tap Start > Programs.
  4. Tap the keyboard program installed in Step 1.
  5. Press the Connect button on the keyboard.
  6. Tap Enable Keyboard on the HP iPAQ device.
  7. If prompted for a passkey, enter it, then tap OK.
  8. To disconnect the HP iPAQ and the keyboard, press the Connect button on the keyboard to turn it off.
Scope: HP iPAQ 200 Enterprise Handheld Series
