    Fix Windows 10 Update Issues
HP Compaq dc7800 Small Form Factor PC - Removing and Replacing the Access panel
This document pertains only to HP Compaq dc7800 Small Form Factor PCs with the following case design:
Before you begin
  • Turn off the computer, and then disconnect all cables. Disconnect the Ethernet or modem cable before disconnecting the power cord.
  • Move the computer to a clear, flat, stable work surface over a non-carpeted floor.
  warning:
Video overview (in English)
To view a video demonstrating the procedure for removing the access panel, right-click Access panel removal video and select Open link in new window/tab.
Replacement part information
The following HP part numbers are known to be compatible with this system:
Part Number
Requires Return
Access panel - Provides access to the inside of chassis
451141-001 (modified)
No
* If a part is listed as "Yes" under "Requires Return" then the defective part needs to be returned to HP. For more information about returning parts to HP select one of the links below:
Review the following safety considerations before performing the following steps. Failure to comply with these safety considerations could result in damage to the product.
Step 1
Remove the cable lock and/or padlock, if they are installed.
Step 2
Push in on the release latch on each side of the access panel.
Step 3
Slide the access panel back about half an inch
Step 4
Lift the access panel off the chassis.
Access panel replacement
Step 1
Position the access panel over the chassis about half an inch back from the front of the computer so that the tabs on the access panel align with the slots on the chassis guide rail.
Step 2
Ensure that the slot in the back of the access panel is aligned with the padlock grommet.
Step 3
Press down and slide the access panel forward until it snaps into place.
