HP Scanjet G3110 - Scanner does not scan right away
If the scanner has not been used for a while, the scanner lamp might need to go through a warm-up period before scanning can begin. If the scanner lamp needs to warm up, it takes a moment after starting the software or pressing a scanner button for scanning to begin.
To change the lamp warm-up setting, open the HP Solution Center, click Settings, and then click Scan Preferences.
