HP Deskjet F735 All-in-One - Horizontal Streaks or Lines in the Printed Image
Issue
The product is working, but the printout shows streaks or lines. The lines run perpendicular to the direction of paper movement through the product and parallel to the movement of the cartridges during printing.
Figure : Streaks or lines, with the direction the paper moved through the product indicated by the arrow
Solution
Follow these steps to resolve the issue.
Step one: Let the All-in-One rest for 30 minutes
Let the product rest for 30 minutes, and then try the print job again.
Step two: Check ink levels and replace low or empty cartridges
Follow these steps to check the ink levels, and then replace low or empty cartridges.
Ink level warnings and indicators provide estimates for planning purposes only. When an indicator shows low ink levels, keep a replacement cartridge available to avoid possible printing delays. Ink cartridges do not need to be replaced until print quality becomes unacceptable.
  1. Open HP Solution Center.
    • Windows XP: On the Windows taskbar, click Start, click All Programs, point to HP, and then click HP Solution Center.
    • Windows Vista: On the Windows taskbar, click the Windows icon (), click All Programs, click HP, and then click HP Solution Center.
  2. Click Settings, and then click Printer Toolbox.
  3. Click the Device Services tab, and then click the Estimated Ink Levels tab.
    Figure : Estimated ink levels
    A cartridge might be running out of ink even if the graphic shows that ink remains in the cartridge. Lines or streaks appear in printouts when the cartridges begin to run out of ink. Replace ink cartridges that are out of or low on ink.
Replace low or empty cartridges
If one of the cartridges is low on ink, follow these steps to replace the low or empty cartridge.
  1. Press the Power button () to turn the product on, if it is not already on.
    If the product is off when the ink-cartridge door is opened, the product will not release the cartridges.
  2. Open the ink-cartridge door. The carriage moves to the far-right side of the product. If the carriage does not move to the right side, turn the product off, and then turn it back on.
      Figure : Open the ink-cartridge door
    1. The carriage
  3. Wait until the carriage is idle and silent, and then lightly press down on an ink cartridge to release it.
    Figure : Remove the ink cartridge
    • To replace the tri-color ink cartridge, remove the ink cartridge from the left slot.
    • To replace the black ink cartridge, remove the ink cartridge from the right slot.
  4. Pull the ink cartridge toward you out of its slot.
  5. Remove the new ink cartridge from its packaging, being careful to touch only the black plastic. Gently remove the plastic tape using the pink pull tab.
      Figure : Remove the tape
    1. Copper-colored contacts (do not touch)
    2. Plastic tape with pink pull tab (remove before installing)
    3. Ink nozzles under tape (do not touch)
    Do not touch the copper-colored contacts or ink nozzles. Touching these parts can result in clogs, ink failure, and bad electrical connections.
    Figure : Do not touch the contacts or ink nozzles
  6. Slide the new ink cartridge at a slight upward angle into the empty slot, and gently push it until it snaps into place.
    • To install a tri-color ink cartridge, insert it into the left slot.
    • To install a black ink cartridge, insert it into the right slot.
    Figure : Install the black ink cartridge on the right
  7. Close the ink-cartridge door.
    Figure : Close the ink-cartridge door
    The product prints a cartridge alignment sheet because it recognizes that the ink cartridges are new. Save this sheet to align the ink cartridges.
    Figure : Cartridge alignment sheet
  1. Open HP Solution Center using one of the following methods.
    • Windows Vista: On the Windows taskbar, click the Windows icon (), click All Programs, point to HP, and then click HP Solution Center.
    The Printer Toolbox opens.
  3. Click the Device Services tab, and then click Align the Print Cartridges. The product prints an ink cartridge alignment sheet.
    Printing alignment sheets shorts the life of ink cartridges. Print them only when necessary.
  4. Lift the product lid.
  5. Place the alignment sheet on the glass so the top of the sheet is on the right side with the text facing down. Make sure that the sheet is aligned with the right-front corner of the glass.
    Figure : Place the alignment sheet on the glass
  6. Lower the product lid.
  7. Press the Scan button () on the product control panel. The product aligns the ink cartridges.
Step three: Check the print settings
Use the following steps to check and adjust the print settings for the product.
  1. In the software application you are trying to print from, click File and then click Print. The Print dialog box opens.
  2. Select your product and then click Preferences. The printer Properties dialog box opens.
  3. Click the Features tab.
  4. Review the following options on the Features tab, and then make any necessary changes.
    • Print quality: If you are not satisfied with the quality of your printouts, increase the print quality. To print more quickly, decrease the print quality.
    • Paper type: If one of the options matches your paper type exactly, choose the matching option rather than Automatic.
    • Resizing Options: Make sure the selected option matches your paper size.
  3. Click the Device Services tab, and then click Clean the Print Cartridges.
  4. Follow the on-screen instructions to complete the task.
  1. Press and hold the Cancel button (), and then press and hold the Start Copy Color button ().
  2. Release both buttons. The diagnostic page prints.
    Figure : The diagnostic page
The product can print with different combinations of ink cartridges. Different cartridge combinations print different diagnostic page patterns. Identify which cartridge printed which part of the diagnostic page to determine the faulty cartridge.
    Figure : Layout of the extended self-test report
  1. Printed by the left (color) cartridge
  2. Printed by the right (black) cartridge
If the product and ink cartridges are working correctly, few or no lines are missing from the grid-like patterns on the diagnostic page. None of the colors should be missing. Also, there should be no streaks of ink on the page.
Missing lines or streaked bars
Color bars will often streak if ink levels are low. If a pattern shows more than a few missing lines, or there are streaks on the bar, the corresponding ink cartridge is not functioning correctly.
Figure : Color block with missing lines
If the diagnostic page shows missing lines or streaked bars, click here to continue troubleshooting (c01480470) (in English).
Missing colors
If any of the color patterns or bars are missing completely, the cartridge is not functioning correctly.
If the product is printing in reserve mode, without all the cartridges installed, the patterns associated with the missing cartridge will also be missing.
    Figure : The yellow pattern and bar are missing
  1. Normal test page
  2. Yellow pattern and bar missing
If any of the patterns or bars are entirely missing from the diagnostic page, click here to continue troubleshooting (c01480143) (in English).
Ink smears
If the diagnostic page shows smeared ink, the cartridges are not functioning correctly.
Figure : Smeared ink
If the diagnostic page shows smeared ink, click here to continue troubleshooting (c01480529) (in English).
Country: Flag Vietnam
