HP 2101nw Wireless G Print Server - The Wireless Network (SSID) Does Not Display in the 'Choose a Wireless Network' List
Issue
The SSID for the product is not visible on the Choose a Wireless Network drop-down list and entering the SSID manually doesn't work.
Solution
  • Check if there is proper power supply to the printer and print server.
  • Unplug and plug in the print server.
  • Check if a firewall is blocking access to the print server. If so, contact the IT department to obtain access to the print server.
  • Check if the print server is on the same subnet as your computer. If not, move the print server to the same subnet.
Cause
  • Either the printer or print server has no power or a cable is unplugged.
  • In a corporate environment, the firewall might be configured to never allow access and might not give any messages
  • The print server might be on a different subnet.
Country: Flag Vietnam
