HP Personal Workstations - Microsoft Windows XP Might Not Boot or Device Drivers Might Not Load when Using the /3GB boot.ini Switch
Issue:
The /3GB switch forces x86-based systems to allocate 3 GB of virtual address space to programs, and 1 GB to the kernel and to executive components. Depending on the hardware and software configuration, the 1 GB for the kernel might be too small, and must be increased a little bit.
Symptoms are, for example:
  • Microsoft Windows XP hangs at boot.
  • Hardware drivers do not load, or fail after a time.
Solution
The fine tuning of the /3GB switch is done with the /userva=xxxx sub switch.
An example of boot.ini is as follows:
multi(0)disk(0)rdisk(0)partition(2)\WINNT="Microsoft Windows XP" /fastdetect /3GB /Userva=2900"
The following Microsoft Knowledge Base Articles contain additional details:
Keywords: OS hangs, Graphics Card, Video, Nvidia, ATI, NIC, Broadcom
