HP Compaq dc7700 Small Form Factor PC - Removing and Replacing the USB/audio assembly
This document is provided to assist in removing and replacing the USB/audio assembly for the HP Compaq dc7700 Small Form Factor PC.
Minimum skill level
Tools required
Torx #15 (T15) screwdriver.
Parts required
The replacement part number will vary depending on the USB/audio assembly that is being replaced. If a part is listed as "Yes" under "Requires Return" then the defective part needs to be returned to HP. Click here for more information on returning parts to HP.
Part Number
Requires Return
USB/Audio interface with attached cable
435262-001 (Modified)
No
Summary of instructions
To view a video demonstrating the procedure for removing the USB/audio assembly, click on the link below. Or use the product video listing on the HP Services Media Library then select USB/audio assembly from the menu on the upper left hand side of the screen.
Right-click on the video link above to open in a new window / tab.
USB/audio assembly removal
  2. Rotate the drive cage to the upright position.
  3. Disconnect the audio and USB cables from the system board.
  4. Pull the cables through the routing post under the drive cage.
  5. From the front of the chassis, remove the two Torx-15 retaining screws.
  6. Push the assembly through the chassis bracket, and then lift and remove it from the chassis.
USB/audio assembly replacement
  1. Position the assembly into its slot in the chassis.
  2. Replace the two retaining screws.
  3. Thread the audio and USB cables through the routing post under the drive cage.
  4. Connect the audio and USB cables to the system board.
  5. Lower the drive cage.
Country: Flag Vietnam
