This document is provided to assist in removing and replacing the Hard drive for the HP Compaq dc7700 Convertible Minitower PC.
- ${title}
- ${title}
hp-hero-support-search
- ${title}
- ${title}
- ${title}
HP Compaq dc7700 Convertible Minitower PC - Removing and Replacing the Hard drive
Minimum skill level
Parts required
The replacement part number will vary depending on the Hard drive that is being replaced. If a part is listed as "Yes" under "Requires Return" then the defective part needs to be returned to HP. Click here for more information on returning parts to HP.
Part Number
Requires Return
80 GB SATA 2 (3 Gb/s) hard drive - 7,200 RPM, 3.5 inches form factor, 1 inch high
432392-001 (Modified)
Yes
160 GB SATA 2 (3 Gb/s) hard drive - 7,200 RPM, 3.5 inches form factor, 1 inch high
432393-001 (Modified)
Yes
250 GB SATA 2 (3 Gb/s) hard drive - 7,200 RPM, 3.5 inches form factor, 1 inch high
432394-001 (Modified)
Yes
Summary of instructions
To view a video demonstrating the procedure for removing the Hard drive, click on the link below. Or use the product video listing on the HP Services Media Library then select Hard drive from the menu on the upper left hand side of the screen.
Click here to view the Hard drive removal video (right-click on the link to open in a new window/tab).
Hard drive removal
Review the safety considerations before performing the steps listed below by clicking on the following link:
Failure to comply with the precautions could result in damage to your product or loss of data. -
Remove the Access panel. Click here for instructions on how to remove the access panel.
This system supports SATA drives only. You do not have to select a cable setting. -
Disconnect the data and power cables from the drive.
Pull out on the green drive release latch and slide the drive out of the drive cage.
If the replacement drive does not include guide screws, remove and reuse the screws from this drive.
Hard drive replacement
Align the guide screws on the drive with the guide slots in the drive bay and push the drive into the bay until it snaps into place.
Connect the power and data cables to the drive.
Replace the Access panel. Click here for instructions on how to replace the access panel.
Parts return
If your part requires return then click on the appropriate link below:
- ${title}
- ${title}
- ${title}
- ${title}
Country/Region:
Vietnam
- ${title}
