HP Color LaserJet CM6030 and CM6040 MFP Series - Control panel menu map and overview information
Control panel overview
The control panel has a VGA touchscreen that provides access to all device functions. Use the buttons and numeric keypad to control jobs and the device status indicated by the LEDs.
Control panel layout
The control panel includes a touchscreen graphical display, job-control buttons, a numeric keypad, and three light-emitting diode (LED) status lights.
  1. Touchscreen
  2. Numeric keypad
  3. Reset button
  4. Sleep button
  5. Stop button
  6. Start button
  7. Attention light
  8. Ready light
  9. Data light
  10. Contrast-adjustment dial
Control panel touchscreen
The touchscreen Home or Home screen provides access to the device features and indicates the current status of the device.
Depending on how the device has been configured, the features that appear on the Home screen can vary.
1
Features
Depending on how the system administrator has configured the device, the features that appear in this area can include any of the following items:
  • Copy
  • Fax
  • E-mail
  • Secondary E-mail
  • Job Status
  • Network Folder
  • Job Storage
  • Workflow
  • Supplies Status
  • Administration
2
Device status line
The status line provides information about the overall device status. Various buttons appear in this area, depending on the current status. For a description of each button that can appear in the status line, see Buttons on the touchscreen.
3
Copy type
Shows whether copies are color.
4
Copy count
The copy count box indicates the number of copies that the device is set to make.
5
Help button
Press the Help button on the touchscreen to open the embedded help system.
6
Scroll bar
On the touchscreen, press the up or down arrows on the scroll bar to see the complete list of available features.
7
Sign Out
On the touchscreen, press Sign Out to sign out of the device if you have signed in for access to restricted features. After you sign out, the device restores all options to the default settings.
8
Network Address
On the touchscreen, press Network Address to find information about the network connection.
9
Date and time
The current date and time appear here. The system administrator can select the format that the device uses to show the date and time, for example 12-hour format or 24-hour format.
The status line on the touchscreen provides information about the status of the device. Various buttons can appear in this area. The following table describes each button.
Home button. On the touchscreen, press the Home button to return to the Home screen from any other screen.
Start button. On the touchscreen, press the Start button to begin the action for the feature that you want to use.
The name of this button changes for each feature. For example, in the Copy feature, the button is named Start Copy.
Stop button. If the device is processing a print or fax job, the Stop button appears instead of the Start button. On the touchscreen, press the Stop button to halt the current job. The device prompts you to cancel the job or to resume it.
Error button. The error button appears whenever the device has an error that requires attention before it can continue. Touch the error button to see a message that describes the error. The message also has instructions for solving the problem.
Warning button. The warning button appears when the device has a problem but can continue functioning. On the touchscreen, press the warning button to view a message that describes the problem. The message also has instructions for solving the problem.
Help button. On the touchscreen, press the help button to open the built-in online Help system. For more information, see Control panel help-system.
The device has a built-in Help system that explains how to use each screen. On the touchscreen, press the Help button in the upper-right corner of the screen to open the Help system.
For some screens, the Help opens to a global menu where you can search for specific topics. You can browse through the menu structure by touching the buttons in the menu.
For screens that contain settings for individual jobs, the Help opens to a topic that explains the options for that screen.
If the device alerts you of an error or warning, touch the error or warning button to open a message that describes the problem. The message also contains instructions to help solve the problem.
Menus overview
From the Home screen, press Administration to open the menu structure. You might need to scroll to the bottom of the Home screen to see this feature.
The Administration menu has several sub-menus, which are listed on the left side of the screen. Press the name of a menu to expand the structure. A plus sign (+) next to a menu name means that it contains sub-menus. Continue opening the structure until you reach the option that you want to configure. To return to the previous level, press Back.
To exit the Administration menu, press the Home button in the upper-left corner of the screen.
The device has built-in Help that explains each of the features that are available through the menus. Help is available for many menus on the right-hand side of the touchscreen. Or, to open the global Help system, press the Help button in the upper-right corner of the screen.
The tables in the following sections appear in order of the structure of each submenu under the Administration menu:
Access the menus
From the Home screen, press Administration to open the menu structure and access the sub-menus.
The Administration menu has several sub-menus, which are listed on the left side of the screen. Touch the name of a menu to expand the structure. A plus sign (+) next to a menu name indicates that it contains sub-menus. Continue opening the structure until you locate the option that you want to configure. To return to the previous level, press Back.
The device has built-in Help that explains each of the features that are available through the menus. Help is available for many menus on the right-hand side of the touchscreen. Or, to open the global Help system, touch the Help button in the upper-right corner of the screen.
The tables in the sections that follow indicate the overall structure of each menu under the Administration menu.
Information menu
Use this menu to print information pages and reports that are stored internally on the device.
Administration > Information
Menu item
Sub-menu item
Sub-menu item
Values
Configuration/Status Pages
Administration Menu Map
Print
Shows the basic structure of the Administration menu and current administration settings.
Configuration/status Pages
Print
A set of configuration pages that show the current device settings.
Supplies Status Page
Print
Shows the status of supplies such as cartridges, maintenance kits, and staples.
Usage Page
Print
Shows information about the number of pages that have been printed on each paper type and size.
Color Usage Job Log
Print
A directory page that contains job-by-job color usage information. Page content includes the user name, application name, and number of black-only pages and color pages.
File Directory
Print
A directory page that contains information for any mass-storage devices, such as flash drives, memory cards, or hard disks, that are installed in this device.
Fax Reports
Fax Activity Log
Print
Contains a list of the faxes that have been sent from or received by this device.
Fax Call Report
Fax Call Report
Print
A detailed report of the last fax operation, either sent or received.
Thumbnail on Report
Yes
No (default)
Choose whether or not to include a thumbnail of the first page of the fax on the call report.
When to Print Report
Never auto print
Print after any fax job
Print after fax send jobs
Print after any fax error (default)
Print after send errors only
Print after receive errors only
Billing Codes Report
Print
A list of billing codes that have been used for outgoing faxes. This report shows how many sent faxes were billed to each code.
Blocked Fax List
Print
A list of phone numbers that are blocked from sending faxes to this device.
Speed Dial List
Print
Shows the speed dials that have been set up for this device.
Sample Pages/Fonts
Demonstration Page
Print
Printout of a page highlighting the print capabilities of the product.
RGB Samples
Print
Printout of color samples for different RGB values. The samples act as a guide for color matching.
CMYK Samples
Print
Printout of color samples for different CMYK values. The samples act as a guide for color matching.
PCL Font List
Print
A list of printer control language (PCL) fonts that are currently available on the device.
PS Font List
Print
A list of PostScript (PS) fonts that are currently available on the device.
Default Job Options menu
Use this menu to define the default job options for each function. These are used if the user does not specify other options when creating the job.
Access the following menus from Administration > Default Job Options.
Default Options for Originals
Default Job Options > Default Options for Originals
Menu item
Values
Paper Size
Select a paper size from the list.
Select the paper size that is most often used for copy or scan originals.
Number of Sides
1
Select whether copy or scan originals are most often single-sided or double-sided.
2
Orientation
Portrait
Select the orientation that is most often used for copy or scan originals. Select Portrait if the short edge is at the top or select Landscape if the long edge is at the top.
Landscape
Optimize Text/Picture
Manually Adjust
Optimize the output for a particular type of original: text, pictures, or a mixture of both.
If you select Manually Adjust, specify the mix of text and pictures that is used most often.
Text
Printed Picture
Photograph
Image Adjustment
Default Job Options > Image Adjustment
Menu item
Values
Darkness
Select a value.
Select the level of density (darkness) for the output.
Background Cleanup
Adjust the value within the range.
Increase the Background Removal setting to remove faint images from the background or to remove a light background color.
Sharpness
Adjust the Sharpness setting to clarify or soften the image.
Default Copy Options
Default Job Options > Default Copy Options
Menu item
Sub-menu item
Values
Number of Copies
Type the number of copies. The factory default setting is 1.
Set the default number of copies for a copy job.
Number of Sides
1
2
Set the default number of sides for copies.
Color/Black
Auto detect
Color
Black (default)
Choose whether the default copy mode is color or black.
Staple/Collate
Staple
None (default)
One left angled
Two left
Two top
One right angled
Two right
Set up options for stapling and collating sets of copies.
If Collate is selected, the device prints a complete copy before starting on the next copy. Otherwise, the device prints the first page of all copies before printing the second page, and so on.
The staple and collate feature may not be present in your product. These features depend on the optional output accessory installed.
Collate
Off
On (default)
Output Bin
<Binname>
Select the default output bin for copies.
This option is available only if an optional output accessory is installed.
Edge-To-Edge
Normal (recommended) (default)
Edge-To-Edge Output
If the original document is printed close to the edges, use the Edge-To-Edge feature to avoid shadows along the edges. Combine this feature with the Reduce/Enlarge feature to ensure that the entire page appears on the copies.
Auto Include Margins
Off (default)
On
This feature automatically reduces the image size during scanning so the margins are included.
Default Fax Options
Default Fax Options > Fax Send
Menu item
Sub-menu item
Values
Resolution
Standard (100x200dpi) (default)
Fine (200x200dpi)
Superfine (300x300dpi)
Set the resolution for sent documents. Higher resolution images have more dots per inch (dpi), so they show more detail. Lower resolution images have fewer dots per inch and show less detail, but the file size is smaller.
Fax Header
Prepend (default)
Overlay
Select the position of the fax header on the page.
Select Prepend to print the fax header above the fax content and move the fax content down on the page. Select Overlay to print the fax header over the top of the fax contents without moving the contents down. Using this option could prevent a single-page fax from flowing onto another page.
Default Fax Options > Fax Receive
Menu item
Sub-menu item
Values
Fax Forwarding
Fax Forwarding
Off (default)
Custom
To forward received faxes to another fax device, select Fax Forwarding and Custom. Then type the number of the other fax device into the Fax Forwarding Number field. When you select this menu item for the first time, you are prompted to set up a PIN. Type that PIN every time you use this menu. This is the same PIN that is used to access the Fax Printing menu.
Create PIN
Stamp Received Faxes
Enabled
Disabled (default)
Add the date, time, senders phone number, and page number to each page of the faxes that this device receives.
Fit to Page
Enabled (default)
Disabled
Shrink faxes that are larger than Letter-size or A4-size so that they can fit onto a Letter-size or A4-size page. If it this feature set to Disabled, faxes larger than Letter or A4 will flow across multiple pages.
Fax Paper Tray
Select from the list of trays. The default setting is Automatic.
Select the tray that holds the size and type of paper that you want to use for incoming faxes.
Output Bin
<Binname>
Select the default output bin, if applicable, to use for faxes.
Default E-mail Options
Default Job Options > Default E-mail Options
Menu item
Values
Document File Type
PDF (default)
JPEG
TIFF
M-TIFF
Select the file format for the e-mail.
Output Quality
High (large file)
Medium (default)
Low (small file)
Selecting higher quality for output increases the size of the output file.
Resolution
300 DPI
200 DPI
150 DPI (default)
75 DPI
Select the resolution. Use a lower setting to create smaller files.
Color/Black
Color scan (default)
Black/white scan
Specify whether the e-mail will be in black or in color.
TIFF Version
TIFF 6.0 (default)
TIFF (Post 6.0)
Specify the TIFF version to use when saving scanned files.
Default Send-to-Folder Options
Default Job Options > Default Send-to-Folder Options
Menu item
Values
Color/Black
Color scan
Black/white scan (default)
Specify whether the file will be in black or in color.
Document File Type
PDF (default)
M-TIFF
TIFF
JPEG
Select the file format for the file.
TIFF version
TIFF 6.0 (default)
TIFF (post 6.0)
Output Quality
High (large file)
Medium (default)
Low (small file)
Resolution
75 DPI
150 DPI (default)
200 DPI
300 DPI
400 DPI
600 DPI
Default Print Options
Default Job Options > Default Print Options
Menu item
Sub-menu item
Values
Copies Per Job
Type a value.
Set the default number of copies for print jobs.
Default Paper Size
(List of supported sizes)
Select a paper size.
Default Custom Paper Size
Unit of measure
Millimeters
Inches
Configure the default paper size that is used when the user selects Custom as the paper size for a print job.
X Dimension
Configure the width measurement for the Default Custom Paper Size.
Y Dimension
Configure the height measurement for the Default Custom Paper Size.
Output Bin
<binname>
Select the default output bin for print jobs. If optional trays are installed, output bin options vary.
Print Sides
1-sided
2-sided
Select whether print jobs are single-sided or double-sided by default.
Time/Scheduling menu
Use this menu to set options for setting the time and for setting the device to enter and exit sleep mode.
Values shown with "(default)" are the factory-default values. Some menu items have no default.
Administration > Time/Scheduling
Menu item
Sub-menu item
Sub-menu item
Values
Date/Time
Date Format
YYYY/MMM/DD (default)
MMM/DD/YYYY
DD/MMM/YYYY
Use this feature to set the current date and time, and to set the date format and time format that are used to time-stamp outgoing faxes.
Date
Month
Day
Year
Time Format
12 hour (AM/PM) (default)
24 hour
Time
Hour
Minute
AM
PM
Sleep Delay
1 Minute
20 minutes
30 minutes (default)
45 minutes
1 hour (60 minutes)
90 minutes
2 hours
4 hours
Use this feature to select the time interval that the device should remain inactive before entering Sleep Mode.
Wake Time
Monday
Tuesday
Wednesday
Thursday
Friday
Saturday
Sunday
Off (default)
Custom
Select Custom to set a wake time for each day of the week. The device exits sleep mode according to this schedule. Using a sleep schedule helps conserve energy and prepares the device for use so that users do not have to wait for it to warm up.
Sleep Time
Monday
Tuesday
Wednesday
Thursday
Friday
Saturday
Sunday
Off (default)
Custom
Use this feature to set a sleep time for each day of the week for periods when the device will not likely be in use (for example, at a certain time each evening). Setting a sleep time makes the device automatically go into a low-power mode. Select a day and then select Custom to set up a custom sleep time schedule.
FAX Printing
Create PIN
If you have concerns about the security of private faxes, use this feature to store faxes rather than having them automatically print by creating a printing schedule. When you select this menu item for the first time, you are prompted to set up a PIN. Type that PIN every time you use this menu.
Management menu
Use this menu to set up global device-management options.
Administration > Management
Menu item
Sub-menu item
Values
Network Address Button
Hide (default)
Use this feature to display the Network Address button on the Home screen.
Stored Job Management
Quick Copy Job Storage Limit
Select the maximum number of jobs to store
Use this menu to view and manage any jobs that are stored on the device.
Quick Copy Job Held Timeout
Off (default)
1 Hour
4 Hours
1 Day
1 Week
Sleep mode
Disable
Use Sleep Delay (default)
Use this feature to customize the sleep mode settings for this device.
Select Use Sleep Delay to set the device to enter sleep mode after the delay that is specified in the Time/Scheduling menu.
Manage Supplies
Replace Supplies
Stop at low
Stop at out (default)
Override at out 1
Override at out 2
This menu sets the product behavior for when a print cartridge, fuser kit, or transfer kit is low. Choose Stop at low to stop printing when a supply reaches a low condition. Choose Stop at out to allow the product to continue printing until a color print cartridge is empty.
Choose Override at out 1 to allow the product to continue printing when the cartridges are empty or when the other supplies are worn out. The product stops printing when the toner collection units are full. Using this option could reduce print quality.
Choose Override at out 2 to allow the product to keep printing when the cartridges are empty; when other supplies are worn out; and when the waste toner collection units are full. Using this option can damage the device.
Supply Low/Order Threshold
Select a value in the range. The default is 5%.
Use this menu to carry out administrative supply management tasks such as changing the threshold when supplies should be ordered.
Color Supply Out
Stop (default)
Auto-continue black
This menu sets the product behavior when a color supply is empty. When Auto-continue black is selected, the product will continue printing using black toner only.
Restrict Color Use
Color printing access
Enable Color (default)
Color If Allowed
Disable Color
This item allows the administrator to disable or restrict color printing. To use the Color If Allowed setting, set up user permissions and/or application permissions in the embedded Web server, HP Easy Printer Care software, or Web Jetadmin.
Color copying access
Disable Color
This item allows the administrator to disable or restrict color copying.
Color/Black Mix
Automatic (default)
Mostly color pages
Mostly black pages
This item controls how the engine switches from color mode to monochrome mode for maximum performance and print cartridge life.
Choose Automatic to reset the product to the factory default setting.
Choose Mostly color pages if nearly all of your print jobs are color with high page coverage.
Choose Mostly black pages if you print mostly monochrome jobs or a combination of color and monochrome jobs.
Initial Setup menu
Access the following menus from the Administration > Initial Setup menus.
Networking and I/O Setup
Administration > Initial Setup > Networking and I/O
Menu item
Sub-menu item
Values
I/O Timeout
Select a value in the range. The factory default setting is 15 seconds.
I/O timeout refers to the elapsed time before a print job fails. If the stream of data that the device receives for a print job gets interrupted, this setting indicates how long the device will wait before it reports that the job has failed.
Embedded Jetdirect
Jetdirect Setup
Administration > Initial Setup > Jetdirect
Menu item
Sub-menu item
Sub-menu item
Values and Description
TCP/IP
Enable
Off: Disable the TCP/IP protocol.
On (default): Enable the TCP/IP protocol.
Host Name
An alphanumeric string, up to 32 characters, used to identify the device. This name is listed on the HP Jetdirect configuration page. The default host name is NPIxxxxxx, where xxxxxx is the last six digits of the LAN hardware (MAC) address.
IPV4 Settings
Config Method
Specifies the method that TCP/IPv4 parameters will be configured on the HP Jetdirect print server.
Bootp: Use BootP (Bootstrap Protocol) for automatic configuration from a BootP server.
DHCP: Use DHCP (Dynamic Host Configuration Protocol) for automatic configuration from a DHCPv4 server. If selected and a DHCP lease exists, DHCP Release and DHCP Renew menus are available to set DHCP lease options.
Auto IP: Use automatic link-local IPv4 addressing. An address in the form 169.254.x.x is assigned automatically.
Manual: Use the Manual Settings menu to configure TCP/IPv4 parameters.
Default IP
Specify the IP address to default to when the print server is unable to obtain an IP address from the network during a forced TCP/IP reconfiguration (for example, when manually configured to use BootP or DHCP).
Auto IP: A link-local IP address 169.254.x.x is set.
Legacy: The address 192.0.0.192 is set, consistent with older HP Jetdirect devices.
DHCP Release
This menu appears if Config Method was set to DHCP and a DHCP lease for the print server exists.
No (default): The current DHCP lease is saved.
Yes: The current DHCP lease and the leased IP address are released.
DHCP Renew
No (default): The print server does not request to renew the DHCP lease.
Yes: The print server requests to renew the current DHCP lease.
Primary DNS
Specify the IP address (n.n.n.n) of a Primary DNS Server.
Secondary DNS
Specify the IP address (n.n.n.n) of a Secondary Domain Name System (DNS) Server.
IPV6 Settings
Enable
Use this item to enable or disable IPv6 operation on the print server.
Off: IPv6 is disabled.
On (default): IPv6 is enabled.
Address
Manual Settings: Use this item to manually set IPv6 addresses on the print server.
Enable: Select this item and choose On to enable manual configuration, or Off to disable manual configuration.
Address: Use this item to type a 32 hexadecimal digit IPv6 node address that uses the colon hexadecimal syntax.
DHCPV6 Policy
Router Specified: The auto-configuration method to be used by the print server is determined by a router. The router specifies whether the print server obtains its address, its configuration information, or both from a DHCPv6 server.
Router Unavailable: If a router is not available, the print server should attempt to obtain its configuration from a DHCPv6 server.
Always: Whether or not a router is available, the print server always attempts to obtain its configuration from a DHCPv6 server.
Primary DNS
Use this item to specify an IPv6 address for a primary DNS server that the print server should use.
Secondary DNS
Use this item to specify an IPv6 address for a secondary DNS server that the print server should use.
Proxy Server
Specifies the proxy server to be used by embedded applications in the device. A proxy server is typically used by network clients for Internet access. It caches Web pages, and provides a degree of Internet security, for those clients.
To specify a proxy server, enter its IPv4 address or fully-qualified domain name. The name can be up to 255 octets.
For some networks, you may need to contact your Independent Service Provider (ISP) for the proxy server address.
Proxy Port
Type the port number used by the proxy server for client support. The port number identifies the port reserved for proxy activity on your network, and can be a value from 0 to 65535.
IPX/SPX
Enable
Off: Disable the IPX/SPX protocol.
On (default): Enable the IPX/SPX protocol.
Frame Type
Selects the frame-type setting for your network.
Auto: Automatically sets and limits the frame type to the first one detected.
EN_8023, EN_II, EN_8022, and EN_SNAP: Frame-type selections for Ethernet networks.
AppleTalk
Enable
Off: Disable the AppleTalk protocol.
On (default): Enable the AppleTalk protocol.
DLC/LLC
Enable
Off: Disable the DLC/LLC protocol.
On (default): Enable the DLC/LLC protocol.
Security
Print Sec Page
Yes (default): Prints a page that contains the current security settings on the HP Jetdirect print server.
No: A security settings page is not printed.
Secure Web
For configuration management, specify whether the embedded Web server will accept communications using HTTPS (Secure HTTP) only, or both HTTP and HTTPS.
HTTPS Required (default): For secure, encrypted communications, only HTTPS access is accepted. The print server will appear as a secure site.
HTTP/HTTPS optional: Access using either HTTP or HTTPS is permitted.
IPSEC
Specify the Firewall status on the print server.
Keep: Firewall status remains the same as currently configured.
Disable: Firewall operation on the print server is disabled.
Reset Security
Specify whether the current security settings on the print server will be saved or reset to factory defaults.
No: The current security settings are maintained.
Yes: Security settings are reset to factory defaults.
Diagnostics
Embedded Tests
This menu provides tests to help diagnose network hardware or TCP/IP network connection problems.
Embedded tests help to identify whether a network fault is internal or external to the device. Use an embedded test to check hardware and communication paths on the print server. After you select and enable a test and set the execution time, you must select Execute to initiate the test.
Depending on the execution time, a selected test runs continuously until either the device is turned off, or an error occurs and a diagnostic page is printed.
LAN HW Test
Running this embedded test will erase your TCP/IP configuration.
This test performs an internal loopback test. An internal loopback test will send and receive packets only on the internal network hardware. There are no external transmissions on your network.
Select Yes to choose this test, or No to not choose it.
HTTP Test
This test checks operation of HTTP by retrieving predefined pages from the device, and tests the embedded Web server.
SNMP Test
This test checks operation of SNMP communications by accessing predefined SNMP objects on the device.
Data Path Test
This test helps to identify data path and corruption problems on an HP postscript level 3 emulation device. It sends a predefined PS file to the device, However, the test is paperless; the file will not print.
Select All Tests
Use this item to select all available embedded tests.
Select Yes to choose all tests. Select No to select individual tests.
Execution Time [H]
Use this item to specify the length of time (in hours) that an embedded test will be run. You can select a value from 1 to 60 hours. If you select zero (0), the test runs indefinitely until an error occurs or device is turned off.
Data gathered from the HTTP, SNMP, and Data Path tests is printed after the tests have completed.
Execute
No: Do not initiate the selected tests.
Yes: Initiate the selected tests.
Ping Test
This test is used to check network communications. This test sends link-level packets to a remote network host, then waits for an appropriate response. To run a ping test, set the following items:
Dest Type
Specify whether the target device is an IPv4 or IPv6 node.
Dest IPv4
Type the IPv4 address.
Dest IPv6
Type the IPv6 address.
Packet Size
Specify the size of each packet, in bytes, to be sent to the remote host. The minimum is 64 (default) and the maximum is 2048.
Timeout
Specify the length of time, in seconds, to wait for a response from the remote host. The default is 1 and the maximum is 100.
Count
Specify the number of ping test packets to send for this test. Select a value from 1 to 100. To configure the test to run continuously, select 0.
Print Results
If the ping test was not set for continuous operation, you can choose to print the test results. Select Yes to print results. If you select No (default), results are not printed.
Execute
Specify whether to initiate the ping test. Select Yes to initiate the test, or No to not run the test.
Ping Results
Use this item to view the ping test status and results using the control panel display. You can select the following items:
Packets Sent
Shows the number of packets (0 - 65535) sent to the remote host since the most recent test was initiated or completed.
Packets Received
Shows the number of packets (0 - 65535) received from the remote host since the most recent test was initiated or completed.
Percent Lost
Shows the percent of ping test packets that were sent with no response from the remote host since the most recent test was initiated or completed.
RTT Min
Shows the minimum detected turnaround round trip time (RTT), from 0 to 4096 milliseconds, for packet transmission and response.
RTT Max
Shows the maximum detected round trip- time (RTT), from 0 to 4096 milliseconds, for packet transmission and response.
RTT Average
Shows the average round-trip-time (RTT), from 0 to 4096 milliseconds, for packet transmission and response.
Ping In Progress
Shows whether a ping test is in progress. Yes indicates a test in progress, and No indicates that a test completed or was not run.
Refresh
When viewing the ping test results, this item updates the ping test data with current results. Select Yes to update the data, or No to maintain the existing data. However, a refresh automatically occurs when the menu times out or you manually return to the main menu.
Link Speed
The link speed and communication mode of the print server must match the network. The available settings depend on the device and installed print server. Select one of the following link configuration settings:
If you change the link setting, network communications with the print server and network device might be lost.
Auto (default): The print server uses auto-negotiation to configure itself with the highest link speed and communication mode allowed. If auto-negotiation fails, either 100TX HALF or 10TX HALF is set depending on the detected link speed of the hub/switch port. (A 1000T half-duplex selection is not supported.)
10T Half: 10 Mbps, half-duplex operation.
10T Full: 10 Mbps, Full-duplex operation.
100TX Half: 100 Mbps, half-duplex operation.
100TX Full: 100 Mbps, full-duplex operation.
100TX Auto: Limits auto-negotiation to a maximum link speed of 100 Mbps.
1000TX Full: 1000 Mbps, full-duplex operation.
Print Protocols
Use this item to print a page that lists the configuration of the following protocols: IPX/SPX, Novell NetWare, AppleTalk, DLC/LLC.
Fax Setup
Administration > Initial Setup > Fax Setup
Menu item
Sub-menu item
Sub-menu item
Values
Required Settings
Country/Region
(Countries/regions listed)
Configure the settings that are legally required for outgoing faxes.
Date/Time
Date Format
Date
Time Format
Time
Fax Header Information
Phone Number
Company Name
PC Fax Send
Disabled
Enabled (default)
Use this feature to enable or disable PC Fax Send. PC Fax Send enables users to send faxes through the device from their computers if they have the Send Fax driver installed on their PC.
Fax Send Settings
Fax Dial Volume
Off
Low (default)
High
Use this feature to set the volume of the tones that you hear while the device dials the fax number.
Error Correction Mode
Enabled (default)
Disabled
When Error Correction Mode is enabled and an error occurs during fax transmission, the device sends or receives the error portion again.
JBIG Compression
Enabled (default)
Disabled
JBIG compression reduces fax-transmission time, which can result in lower phone charges. However, using JBIG compression sometimes causes compatibility problems with older fax machines. If this occurs, turn off JBIG compression.
Maximum Baud Rate
Select a value from the list. The default is 33.6K.
Use this feature to set the maximum baud rate for receiving faxes. This can be used as a diagnostic tool for troubleshooting fax problems.
TCF T.30 Delay Timer
Default (default)
Custom
This setting should be left at the default value and only changed when directed by an HP technical support agent. Adjustment procedures associated with this setting are beyond the scope of this guide.
TCF Extend
Default (default)
Custom
Dialing Mode
Tone (default)
Pulse
Select whether the device should use tone or pulse dialing.
Redial On Busy
The range is between 0 and 9. The factory default is 3 times.
Type the number of times the device should attempt to redial if the line is busy.
Redial On No Answer
Never (default)
Once
Twice
Use this feature to specify the number of times the device should attempt to dial if the recipient fax number does not answer.
Twice is available in locations other than the United States and Canada.
Redial Interval
The range is between 1 and 5 minutes. The factory default is 5 minutes.
Use this feature to specify the number of minutes between dialing attempts if the recipient number is busy or not answering.
Detect Dial Tone
Enabled
Disabled (default)
Use this feature to specify whether the device should check for a dial tone before sending a fax.
Dialing Prefix
Off (default)
Custom
Use this feature to specify a prefix number that must be dialed when sending faxes from the device.
Billing Codes
Off (default)
Custom
When billing codes are enabled, a prompt appears that asks the user to enter the billing code for an outgoing fax.
The range is between 1 and 16 digits. The default is 1 digit.
Fax Receive Settings
Rings To Answer
The range varies by location. The factory default is 2 rings.
Use this feature to specify the number of rings that must occur before the fax modem answers.
Ring Interval
Default (default)
Custom
This setting is used to adjust for some PBX ring signals. Change this setting only when directed by an HP technical support agent.
Ring Frequency
Default (default)
Custom
Ringer Volume
Off
Low (default)
High
Set the volume for the fax ring-tone.
Blocked Fax Numbers
Add Blocked Numbers
Type the fax number to add.
Use this feature to add or delete numbers from the blocked fax list. The blocked fax list can contain up to 30 numbers. When the device receives a call from one of the blocked fax numbers, it deletes the incoming fax. It also logs the blocked fax in the activity log along with job-accounting information.
Remove Blocked Numbers
Select a fax number to remove.
Clear All Blocked Numbers
No (default)
Yes
E-mail Setup
Use this menu to enable the e-mail feature and to configure basic e-mail settings.
To configure advanced e-mail settings, use the embedded Web server. For more information, see Embedded Web server.
Administration > Initial Setup > E-mail Setup
Menu item
Values
Address Validation
On (default)
Off
This option enables the device to check e-mail syntax when you type an e-mail address. Valid e-mail addresses require the "@" sign and a ".".
Find Send Gateways
Search the network for SMTP gateways that the device can use to send e-mail.
SMTP Gateway
Enter a value.
Specify the IP address of the SMTP gateway that is used to send e-mail from the device.
Test Send Gateway
Test the configured SMTP gateway to see if it is functional.
Send Setup
Administration > Initial Setup > Send Setup
Menu item
Values
Fax Number Confirmation
Disable (default)
Enable
When fax number confirmation is enabled, you are prompted to enter the fax number twice to verify that it has been typed correctly.
Device Behavior menu
Administration > Device Behavior
Menu item
Sub-menu item
Sub-menu item
Values
Language
Select the language from the list.
Select a different language for control-panel messages. When you select a new language, the keyboard layout might also change.
Key Press Sound
On (default)
Off
Use this feature to specify whether you hear a sound when you touch the screen or press buttons on the control panel.
Inactivity Timeout
Type a value between 10 and 300 seconds. The factory default is 60 seconds.
Specify the amount of time that elapses between any activity on the control panel and the device resetting to the default settings.
Warning/Error Behavior
Clearable Warnings
On
Job (default)
Set the amount of time that a clearable warning appears on the control panel.
Continuable Events
Auto continue (10 seconds) (default)
Touch OK to continue
Configure the device behavior when the device encounters certain errors.
Jam Recovery
Auto (default)
Off
On
Configure how the device handles pages that are lost during a jam.
Tray Behavior
Use Requested Tray
Exclusively (default)
First
Control how the device handles jobs that have specified a specific input tray.
Manually Feed Prompt
Always (default)
Unless Loaded
Specify how a prompt should appear when the type or size for a job does not match the specified tray and the device pulls from the multipurpose tray instead.
PS Defer Media
Enabled (default)
Disabled
Select either the PostScript (PS) or HP paper-handling model.
Use Another Tray
Enabled (default)
Disabled
Turn on or off the control-panel prompt to select another tray when the specified tray is empty.
Size/Type Prompt
Display (default)
Do not display
Control whether the tray configuration message appears whenever a tray is opened or closed.
Duplex Blank Pages
Auto (default)
Yes
Control how the device handles two-sided jobs (duplexing).
Image Rotation
Left to Right
Right to Left
Alternate
Image rotation allows users to put paper in the input tray using the same orientation regardless of whether there is a finisher installed.
The image rotation set in this menu will be applied any time a job does not request stapling or when the requested stapling could not be applied because of unsupported media or when the stapler is unavailable.
Select Left to Right to rotate the image as if it were going to be bound on the left. This setting is appropriate for print jobs where reading from left to right is the cultural norm. This is the default setting.
Select Right to Left to rotate the image as if it were going to be bound on the right. This setting is usually appropriate for print jobs where reading from right to left is the cultural norm.
Select Alternate to use a different loading orientation that might work better with preprinted forms that are used on legacy products.
Multifunction Finisher
or
MBM-3 Bin Stapler
Operation Mode
Mailbox
Stacker
Function Separator
This menu appears when the HP 3-bin Stapler/Stacker Accessory or the HP Booklet Maker/Finisher Accessory is attached.
Allows you to set the default operation mode. Mailbox assigns a user or group of users to each output bin. Stacker treats all of the output bins as a single large bin. When one bin gets full, jobs are automatically routed to the next bin. Function Separator specifies a default bin for specific types of jobs such as faxes or copies (stapler/stacker only).
Staples
None
One Left Angled
One Right Angled
Two Left
Two Right
Two Top
Sets the default staple selection for documents sent to the device when no staple value is specified.
Staples Out
Stop
Continue
Sets the default behavior when a job specifies stapling and the stapler is out of staples. Stop stops printing if the stapler runs out of staples. Continue allows a job to continue printing even when the device is out of staples.
Offset
Off
On
Turns the job offset feature on or off. When job offset is on, each copy of a job is shifted to one side in the output bin in order to keep each copy separate from the others.
A4/Letter Staple
Normal
Alternate 1
Alternate 2
Controls the speed of the print engine to prevent paper jams by using the stapler buffer.
The stapler buffer may or may not be used depending on the selected media type or on the sensed media type, if Audodetect or Autosense Mode is enabled.
If the Normal setting is enabled, the engine speed will be normal by using the stapler buffer whenever possible.
If the Alternate 1 setting is enabled, and the engine is in Autodetect or Autosense Mode, the engine slows down to prevent jams. If the product is NOT in Autosense Mode, the engine performs at normal speed, using the stapler buffer whenever possible.
If the Alternate 2 setting is enabled, the engine always slows down to prevent jams, never using the stapler buffer.
Fold LTR-R & A4 - R
–4.0 mm
–3.5 mm
–3.0 mm
–2.5 mm
–2.0 mm
–1.5 mm
–1.0 mm
–0.5 mm
0.0 mm
0.5 mm
1.0 mm
1.5 mm
2.0 mm
2.5 mm
3.0 mm
3.5 mm
4.0 mm
Adjusts the fold line for Letter and A4 size paper (booklet maker only).
Fold Legal & JISB4
–4.0 mm
–3.5 mm
–3.0 mm
–2.5 mm
–2.0 mm
–1.5 mm
–1.0 mm
–0.5 mm
0.0 mm
0.5 mm
1.0 mm
1.5 mm
2.0 mm
2.5 mm
3.0 mm
3.5 mm
4.0 mm
Adjusts the fold line for Legal and JIS B4 size paper (booklet maker only).
Fold 11X17 & A3
–4.0 mm
–3.5 mm
–3.0 mm
–2.5 mm
–2.0 mm
–1.5 mm
–1.0 mm
–0.5 mm
0.0 mm
0.5 mm
1.0 mm
1.5 mm
2.0 mm
2.5 mm
3.0 mm
3.5 mm
4.0 mm
Adjusts the fold line for Legal and 11x17 and A3 size paper (booklet maker only).
General Copy Behavior
Scan Ahead
Enabled (default)
Disabled
Turn on no-wait scanning. With Scan Ahead enabled, the pages in the original document are scanned to disk and held until the device becomes available.
Auto Print Interrupt
Enabled
Disabled (default)
When this feature is enabled, copy jobs can interrupt print jobs that are set to print multiple copies.
The copy job is inserted into the print queue at the end of one copy of the print job. After the copy job is complete, the device continues printing the remaining copies of the print job.
Copy Interrupt
Enabled
Disabled (default)
When this feature is enabled, a copy job that is currently printing can be interrupted when a new copy job is started. You are prompted to confirm that you want to interrupt the current job.
Alternative Letterhead Mode
Off (default)
On
This option allows loading of letterhead or preprinted paper the same way for all copy jobs, whether copying to one side of the paper or to both sides of the paper.
General Printing Behavior
Override A4/Letter
No
Yes (default)
When this feature is enabled, the job prints on letter-size paper when an A4 job is sent but no A4-size paper is loaded in the device (or prints on A4 paper when a letter-size job is sent but no letter-size paper is loaded). This option also overrides A3 with ledger-size paper and ledger with A3-size paper.
Manual Feed
Enabled
Disabled (default)
When this feature is enabled, the user can select manual feed from the control panel as the paper source for a job.
Courier Font
Regular (default)
Dark
Select which version of the Courier font you want to use.
Wide A4
Enabled
Disabled (default)
Change the printable area of A4-size paper. If you enable this option, eighty 10-pitch characters can be printed on a single line of A4 paper.
Print PS Errors
Enabled
Disabled (default)
Select whether a PostScript (PS) error page is printed when the device encounters a PS error.
Print PDF Errors
Enabled
Disabled (default)
Select whether a PDF error page is printed when the device encounters a PDF error.
Personality
Auto (default)
PCL
PDF
PS
Select the printer language that the device should use.
Normally, you should not change the language. If you change the setting to a specific language, the device does not automatically switch from one language to another unless specific software commands are sent to the device.
PCL
Form Length
Type a value between 5 and 128 lines. The factory default is 60 lines.
PCL is a set of printer commands that Hewlett-Packard developed to provide access to printer features.
Orientation
Portrait (default)
Landscape
Select the orientation that is most often used for print jobs. Select Portrait if the short edge is at the top or Landscape if the long edge is at the top.
Font Source
Select the source from the list.
Select the font source for the user-soft default font.
Font Number
Type the font number. The range is between 0 and 999. The factory default is 0.
Specify the font number for the user soft default font by using the source that is specified in the Font Source menu item. The device assigns a number to each font and lists it on the PCL font list (available from the Administration menu).
Font Pitch
Type a value between 0.44 and 99.99. The factory default is 10.00.
If Font Source and Font Number indicate a contour font, use this feature to select a default pitch (for a fixed-spaced font).
Symbol Set
PC-8 (default)
(50 additional symbol sets from which to choose)
Select any one of several available symbol sets from the control panel. A symbol set is a unique grouping of all the characters in a font.
Append CR to LF
No (default)
Yes
Configure whether a carriage return (CR) is appended to each line feed (LF) encountered in backwards-compatible PCL jobs (pure text, no job control).
Suppress Blank Pages
No (default)
Yes
This option is for users who are generating their own PCL, which could include extra form feeds that cause blank pages to be printed. When Yes is selected, form feeds are ignored if the page is blank.
Media Source Mapping
Standard (default)
Classic
Select and maintain input trays by number when you are not using the device driver, or when the software program has no option for tray selection.
Print Quality menu
Administration > Print Quality
Menu item
Sub-menu item
Values
Adjust Color
Highlights
Cyan Density. Magenta Density. Yellow Density. Black Density
+5 to –5. Default is 0.
Adjust the darkness or lightness of highlights on a printed page. Lower values represent lighter highlights on a printed page, and higher values represent darker highlights on a printed page.
Midtones
Adjust the darkness or lightness of midtones on a printed page. Lower values represent lighter midtones on a printed page, and higher values represent darker midtones on a printed page.
Shadows
Adjust the darkness or lightness of shadows on a printed page. Lower values represent lighter shadows on a printed page, and higher values represent darker shadows on a printed page.
Restore Color Values
Sets all the density values back to the factory default settings.
Set Registration
Test Page
Print
Shift the margin alignment to center the image on the page from top to bottom and from left to right. You can also align the image on the front with the image printed on the back.
Print a test page for setting the registration.
Source
All trays
Tray <X>: <contents> (choose a tray)
Select the source input tray for printing the Set Registration page.
Adjust Tray <X>
Shift from -20 to 20 along the X or Y axes. 0 is the default.
X1 Shift
X2 Shift
Y Shift
Perform the alignment procedure for each tray.
When it creates an image, the device scans across the page from side to side as the sheet feeds from top to bottom into the device.
The scan direction is referred to as X. X1 is the scan direction for the first side of a 2-sided page. X2 is the scan direction for the second side of a 2-sided page. The feed direction is referred to as Y.
Print Modes
<Paper Type>
Configure which mode is associated with which paper type.
Auto Sense Mode
Tray 1 sensing
Full Sensing (default for Tray 1)
Expanded Sensing (default for Trays 2-5)
Transparency Only
When Full Sensing is selected, the product recognizes light, plain, heavy, glossy, and tough paper and overhead transparencies. When Expanded Sensing is selected, the device recognizes normal paper, overhead transparencies, glossy paper, and tough paper. When Transparency Only is selected, the device recognizes only overhead transparency and non-overhead transparency types.
Tray 2-5 Sensing
Expanded Sensing
Transparency Only (default)
Optimize
Paper Curl
Normal
Reduced
To help reduce paper curl, set this option to Reduced. This decreases full speed to 10 PPM (instead of 40 ppm) and 3/4 speed to 7.5 ppm (instead of 30 ppm).
Pre-rotation
Off (default)
On
Turn this feature On if horizontal streaks appear on pages. Using this feature increases the warm-up time for the device.
Fuser Temp
Normal (default)
Alternate 1
Alternate 2
Alternate 3
If you are seeing a faint image of the page repeated at the bottom of the page or on the following page, you should first make sure the Paper Type and Print Mode settings are correct for the type of paper you are using. If you continue to see ghost images on your print jobs, set the Fuser Temp feature to one of the Alternate settings . Try the Alternate 1 setting first and see if it solves the problem. If you continue to see the problem, try Alternate 2 and then Alternate 3. With the Alternate 2 and Alternate 3 settings you may see an extra delay between jobs.
Tray 1
Normal (default)
Alternate
If you are seeing marks on the back side of the paper when printing from Tray 1, set the mode to Alternate. This increases the frequency of the cleaning cycle.
Gloss Mode
Normal (default)
High
Chosen when stable high gloss is required. Set this feature to High for glossy print jobs, such as photos, if you notice the gloss finish decreasing after the first page is printed. This setting reduces the performance for all paper types.
Light Media
Auto (default)
On
Prevents the fuser from wrapping with light paper. Set this feature to On if you are frequently seeing Fuser Delay Jam or Fuser Wrap Jam messages, especially when printing on lightweight paper or on jobs with heavy toner coverage.
Environment
Normal (default)
Low Temp
Optimizes performance in extreme low temperature environments. Set this feature to Low Temp if the product is operating in a low-temperature environment and you are having problems with print quality such as blisters in the printed image.
Line Voltage
Normal (default)
100V
Optimizes performance in low-voltage conditions. Set this feature to 100V if the product is operating in a low-voltage environment and you are having problems with print quality such as blisters in the printed image.
Cleaning frequency
Normal (default)
Alternate
Set this feature to Alternate if you are seeing defects in the printed output that repeat at 38 mm (1.5 inch) intervals. This feature increases the frequency at which the C roller is cleaned. Setting this feature to Alternate might also reduce printing speed and increase the frequency of consumable replacement.
D-Blade bias
Normal (default)
Alternate
Set this feature to Alternate if you are seeing short white vertical lines in the printed output. The Alternate setting might also cause dark spots in the printed output, so be sure to test this setting on a few print jobs.
Waste Bin
Normal (default)
Alternate
Try setting this feature to Alternate if you are seeing lengthwise toner streaks in your printed output, especially in jobs with low toner coverage.
Discharge Brush
Off (default)
On
Enable this feature in low temperature and low humidity environments if you are seeing specks of toner scattered on double-sided jobs using light-weight paper and longer than ten pages.
Background
Off (default)
On
Turn this feature On if pages are printing with a shaded background. Using this feature might reduce gloss levels.
Heavy Mode
30 PPM (default)
24 PPM
The default setting is 30 PPM. Select the 24 PPM option to reduce the speed and improve fusing on heavy paper.
Tracking Control
Off (default)
On
Improves color stability by adjusting the bias voltage. This setting should remain On.
Restore Optimize
Select this setting to return all the settings in the Optimize menu to the factory default settings.
Resolution
Image REt 4800
1200X600dpi
Select Image REt 4800 to produces fast, high-quality printing that is appropriate for most print jobs
Select 1200X600dpi to produce the highest-quality printing available, but it may slow print speed. This setting may be useful for jobs that contain very thin lines or fine graphics.
Color REt
Enabled (default)
Disabled
Enable or disable Resolution Enhancement technology (REt), which produces print output with smooth angles, curves, and edges.
Calibration/Cleaning
Process Cleaning Page
Process
Use this feature to create and process a cleaning page for cleaning excess toner off the pressure roller in the fuser. The process takes up to 2.5 minutes.
Quick Calibration
Calibrate
Performs partial product calibrations.
Full Calibration
Calibrate
Performs all product calibrations.
Delay Calibration At Wake/Power On
No
Yes (default)
This menu controls the timing of the calibration when the printer wakes up or is turned on.
  • Select No to have the printer calibrate immediately when it wakes up or is turned on. The device will not print any jobs until it finishes calibrating.
  • Select Yes to enable a device that is asleep to accept print jobs before it calibrates. The device only accepts new jobs for a short time. It may start calibrating before it has printed all the jobs it has received.
For the best results, allow the device to calibrate before printing. Print jobs performed before calibration may not be of the highest quality.
Troubleshooting menu
Many of the menu items under the Troubleshooting menu are for advanced troubleshooting purposes.
Administration > Troubleshooting
Menu item
Sub-menu item
Sub-menu item
Values
Event Log
Print
This shows the event codes and their corresponding engine cycles on the control-panel display.
Calibrate Scanner
Calibrate
Use this feature to compensate for offsets in the scanner imaging system (carriage head) for ADF and flatbed scans.
You might need to calibrate the scanner if it is not capturing the correct sections of scanned documents.
PQ Troubleshooting
Print
Print various diagnostic pages that help solve print-quality problems.
Fax T.30 Trace
Print T.30 Report
Print or configure the fax T.30 trace report. T.30 is the standard that specifies handshaking, protocols, and error correction between fax machines.
Never auto print (default)
Fax Transmit Signal Loss
A value between 0 and 30. The default is 0.
Set loss levels to compensate for phone-line signal loss. Do not modify this setting unless requested to do so by an HP service representative because it could cause the fax to stop functioning.
Fax V.34
Normal (default)
Off
Disable V.34 mode if several fax failures have occurred or if phone line conditions require it.
Fax Speaker Mode
Normal (default)
Diagnostic
A technician can use this feature technician to evaluate and diagnose fax issues by listening to the sounds of fax modulations.
Diagnostic Page
Print
Print a diagnostic page that includes color swatches and the EP parameters table.
Disable Cartridge Check
Use this item to enter a mode where a cartridge (or color pair of cartridge and drum) can be removed to determine which particular color is the source of a problem. In this mode, all consumable-related errors are ignored.
Paper Path Sensors
Initiate a test of the paper-path sensors.
Paper Path Test
Test Page
Print
Generate a test page for testing the paper-handling features. Define the path for the test in order to test specific paper paths.
Source
All trays
Tray 1
Tray 2
(Additional trays are shown, if applicable.)
Specify whether the test page is printed from all trays or from a specific tray.
Destination
All bins
Select the output option for the test page. Send the test page to all output bins or only to a specific bin.
Duplex
Off (default)
On
Select whether the duplexer should be included in the test.
Copies
Range: 1-500, Default is 1.
Select how many pages should be sent from the specified source as part of the test.
Finishing Paper Path Test
Staples
Finishing Options
Choose from a list of available options.
Test the paper-handling features on the finisher.
Select the option that you want to test.
Destination Bin
Media Size
Letter
A4
Select the paper size for the test.
Media Type
Select from a list of types.
Select the paper type for the test.
Copies
Range: 2-30, Default=2
Select the number of copies to include in the test.
Duplex
Off
On
Select whether to use the duplexer in the test.
Test Page
Print
Print a test page to use for the test.
Stack
Destination Bin
Select from a list of bins.
Select the options that you want to use to test the stacker.
Media Size
Letter
Legal
A4
Executive (JIS)
8.5 x 13
Media Type
Select the type of media to use for the Finishing Paper Path Test.
Copies
1
10
50
100
500
Select the number of copies to include in the Finishing Paper Path Test.
Duplex
Off
On
Select whether to use the duplexer in the Finishing Paper Path Test.
Test Page
Print
Booklet Maker
Media Size
Letter
Legal
A4
Executive (JIS)
8.5 x 13
Select the options that you want to use to test the booklet maker.
Media Type
Copies
1
10
50
100
500
Duplex
Off
On
Test Page
Print
Manual Sensor Test
This item performs tests to determine whether the paper-path sensors are operating correctly.
Component Test
Transfer Motors
Belt Only
Image Drum Motors
Black Laser Scanner
Cyan Laser Scanner
Magenta Laser Scanner
Yellow Laser Scanner
Fuser Motor
Fuser Pressure Release Motor
Black Alienation Motor
Cyan Alienation Motor
Magenta Alienation Motor
Yellow Alienation Motor
ITB Contact/Alienation
Tray 2 Pickup Motor
Tray 2 Pickup Solenoid
Tray 3 Pickup Motor
Tray 3 Pickup Solenoid
Tray 4 Pickup Motor
Tray 4 Pickup Solenoid
Tray 5 Pickup Motor
Tray 5 Pickup Solenoid
Duplexer Reverse Motor
Duplexer Feed Motor
Duplexer ReFeed Motor
Paper Transport Motor
Exercise individual parts independently to isolate noise, leaking, or other issues. To start the test, select one of the components. The test runs the number of times specified in the Repeat option. You might be prompted to remove parts from the device during the test. Press the Stop button to abort the test.
Repeat
Once (Default)
Continuous
Determines the number of times the test runs.
Print/Stop Test
Continuous value from 0 to 60,000 milliseconds. Default: 0
Isolate faults by stopping the device during the print cycle and observing where in the process the image degrades. To run the test, specify a stop time. The next job that is sent to the device stops at the specified time in the process.
Color Band Test
Test Page
Print
Prints a page that helps identify arcing in the high-voltage power supplies.
Copies
Continuous value from 1 to 30.
Default: 1
Specify the number of copies to print for the Color Band test
Scanner Tests
Lower Lamp
Sensors
ADF Input Motor
ADF Input Reverse
Flatbed Motor
ADF Read Motor
ADF Read Motor Reverse
ADF Duplex Solenoid
ADF LED Indicator
A service technician can use this menu item to diagnose potential problems with the device scanner.
Control Panel
LEDs
Verify that the components of the control panel are functioning correctly.
Buttons
Touchscreen
Finisher Tests
Manual Sensor Test
Component Test
Resets menu
Administration > Resets
Menu item
Values
Clear Local Address Book
Clear
Use this feature to clear all addresses from the address books that are stored on the device.
Clear Fax Activity Log
Yes
No (default)
Use this feature to clear all events from the Fax Activity Log.
Restore Factory Telecom Setting
Restore
Use this option to restore the following settings to their factory default settings: Transmit Signal Loss, V34, Maximum Baud Rate, Speaker Mode.
Restore Factory Settings
Restore
Use this feature to restore all device settings to their factory defaults.
Reset Supplies
New Document Feeder Kit (Yes/No)
Notify the device that a new document-feeder kit has been installed.
Service menu
Access the following menus from Administration > Service.
The Service menu is locked and requires a PIN for access. This menu is intended for use by authorized service personnel.
