HP Compaq 2133 Mini-Note PC - Overview
Product description
Ideal for instructional use or general purpose business applications, the HP Compaq 2133 Mini-Note PC might be small in size (2.8 lb /1.27 kg and only 1.05 in/33 mm thin) but it’s big on usability, durability, and sleekness. Packed with an impressive combination of features, the HP Compaq 2133 offers you a full-function PC with the utmost mobility.
Product features
Feature
Processor
  • VIA C7-M ULV processor (1.0 GHz, 128 KB L2 cache, 400 MHz FSB)
  • VIA C7-M ULV processor (1.2 GHz, 128 KB L2 cache, 800 MHz FSB)
  • VIA C7-M ULV processor (1.6 GHz, 128 KB L2 cache, 800 MHz FSB)
Processor speed denotes maximum performance mode; processors will run at lower speeds in battery optimization mode.
  • VIA 896
Memory
Standard (one SODIMM slot)
  • 512 MB 667 MHz DDR2 SDRAM SODIMM
  • 1024 MB 667 MHz DDR2 SDRAM SODIMM
  • 2048 MB 667 MHz DDR2 SDRAM SODIMM
Maximum
  • Supports up to 2048 MB maximum
An 800 MHz DDR2 SDRAM SODIMM memory module may be substituted (running at the maximum system supported speed of 667 MHz)
Due to the non-industry standard nature of some third-party memory modules, we recommend HP branded memory to ensure compatibility.
Storage
Internal Storage Device
  • 120/160 GB 5400 rpm SATA Hard Drive
  • 120/160 GB 7200 rpm SATA Hard Drive
Hard drives are customer removable and will withstand multiple insertion/removal cycles. Up to 10 GB is reserved for the system recovery software.
HP 3D DriveGuard (Windows models only)
  • The hard drive is mounted to the notebook frame, reducing the transmission of shock away from the hard drive. Uses three-axis digital motion detection with intelligent sensitivity to help protect the hard drive during normal use from shock and vibration. The digital accelerometer temporarily halts all data transfer and parks the hard drive when abrupt motion is detected.
External Optical Drives (Via optional HP External MultiBay II (9.5-mm))
  • MultiBay II DVD-ROM Drive
  • MultiBay II DVD/CD-RW Combo Drive
  • MultiBay II DVD+/-RW SuperMulti DL Drive
Internal
  • 8.9-inch WXGA display with 1280 x 768 resolution
  • 8.9-inch WSVGA display with 1024 x 600 resolution
  • Scratch-resistant treatment on acrylic panel cover
External
  • Up to 32-bit per pixel color depth
  • VGA port supports resolutions up to 2048 x 1536 at 75 Hz, and lower resolutions at up to 100 Hz
Resolutions are dependent upon monitor capability, and resolution and color depth settings.
Graphics
  • VIA Chrome 9
    • Up to 256 MB of shared system memory for Windows with 2 GB of system memory
    • Up to 128 MB of shared system memory for Windows with 1 GB of system memory
    • Up to 64 MB of shared system memory for Linux
Power
Power Supply
  • External 65-watt Smart AC adapter, 6-foot (1.8-meter) power cord included
  • Total length including External AC adapter is 12 feet (3.66 meter)
  • HP Fast Charge Technology
Fast Charge Technology recharges your battery up to 90% within 90 minutes when the system is off. Fast Charge Technology does not apply to 12-cell Ultra-Capacity batteries.
Battery
  • 3-cell (28 WHr) high capacity Li-Ion
  • 6-cell (55 WHr) high capacity Li-Ion
Battery life
  • 3-cell Primary Battery - Up to 2 hours 15 minutes
  • 6-cell Primary Battery - Up to 4 hours 30 minutes
The listed battery life measurements were taken on models running Microsoft Windows Vista. Battery life will vary depending on the product configuration, product model, applications loaded on the product, power management settings of the product, and the product features used by the customer. As with all batteries, the maximum capacity of this battery will decrease with time and usage.
System Standby Time
  • Up to 1 week
Audio
  • ADI1984HD High Definition CODEC
  • 24-bit DAC
  • Integrated stereo speakers
  • Stereo headphone/line out
  • Stereo microphone in
Wireless Devices
Support for secure, integrated wireless LAN options featuring support for the latest industry standards. Wireless LAN is factory configurable only. Integrated Bluetooth is also available (factory configurable only) and can be combined with any of the supported wireless LAN options.
All 802.11 integrated wireless LAN options
  • Wi-Fi CERTIFIED
    The specifications for 802.11n draft 2.0 are draft specifications and are not final. If the final specifications differ from the draft specifications, it may affect the ability of the notebook to communicate with other 802.11n WLAN devices. In countries where n draft 2.0 is not allowed, this capability is not enabled.
  • Cisco Compatible Extensions support (Version 4.0)
  • Wired Equivalent Privacy (WEP) support up to 128-bit keys
  • Wi-Fi Protected Access (WPA) and WPA2 support
  • 802.1x authentication support, including EAP-TLS, EAP-TTLS, PEAP-GTC, PEAP-MSCHAPv2, and LEAP
  • Advanced Encryption Standard (AES) support
  • WiFi certified for WPA2, WMM Dual antennas integrated in the display enclosure
Broadcom 4322AGN 802.11a/b/g/draft-n
  • Wi-Fi Adapter Integrated support for 802.11a, b, g, and n draft 2.0
  • Up to 300 mbps data rate
Broadcom 4311AG 802.11a/b/g
  • Wi-Fi Adapter Integrated support for 802.11 a, b and g
  • Up to 54-mbps data rate
Broadcom 4312G 802.11b/g
  • Wi-Fi Adapter Integrated support for 802.11 b and g
HP Integrated Module with Bluetooth Wireless Technology
  • Bluetooth Specification v2.0 compliant
  • Works with a wide range of Bluetooth devices
Communications
  • Integrated Broadcom NetLink Gigabit Ethernet PCI Controller (10/100/1000 NIC)
Expansion card slots
ExpressCard/54 slot
  • Supports ExpressCard/54 and ExpressCard/34
Secure Digital slot
  • Supports HCSD (Secure Digital), MMC (MultiMedia Card)
Interfaces
  • ExpressCard/54 slot - Supports ExpressCard/54 and ExpressCard/34
  • External Monitor One - VGA
  • Stereo Microphone In - One
  • Stereo Headphone/Line out - One
  • Power Connector - One
  • RJ-45/Ethernet - One
  • USB 2.0 - Two (one powered)
  • LED Status Indicators - Five
Keyboard
  • Spill-resistant keyboard is 92% of full size, 101/102-key compatible with isolated inverted-T cursor control keys, both left and right control and alt keys, 12 function keys, and hotkey combinations for audio volume, power conservation, brightness, and other features. US and international key layouts are available.
Pointing device
  • Touchpad with scroll zone and two soft-touch buttons
Software overview
Feature
Operating System
Preinstalled
  • Genuine Windows Vista Home Basic 32
  • Genuine Windows Vista Business 32
  • Genuine Windows Vista Business downgrade to Genuine Windows XP Professional installed
  • SuSE Linux Enterprise Desktop 10
  • Genuine Windows XP Home Edition (China only)
  • FreeDOS
Supported
  • Genuine Windows XP Professional
Certain Windows Vista product features require advanced or additional hardware. See http://www.microsoft.com/windowsvista/getready/hardwarereqs.mspx and http://www.microsoft.com/windowsvista/getready/capable.mspx for details. Windows Vista Upgrade Advisor can help you determine which features of Windows Vista will run on your computer. To download the tool, visit http://www.windowsvista.com/upgradeadvisor.
Windows Vista Business disk also included for future upgrade if desired. To qualify for this downgrade an end user must be a business (including governmental or educational institutions) and is expected to order annually at least 25 customer systems with the same custom image.
Preinstalled Software with Windows Vista or Windows XP
  • MS Office Ready 2007
  • Norton Internet Security
  • MS Live Messenger
  • Adobe Flash Player
  • Roxio Creator Basic
  • Intervideo WinDVD
  • PDF Complete SE
  • HP Webcam
  • HP Recovery Manager (Vista only)
Preinstalled Software with SuSE Linux Enterprise Desktop 10
  • OpenOffice Suite
  • Evolution Email
  • Evince Document Viewer
  • OpenOffice Draw
  • F-Spot Photo Browser
  • Gnome CD/DVD Creator
  • Helix Banshee Music Player
  • Real Player 10
  • Media Player
  • Firefox Web Browser
  • Gaim Instant Messenger
  • Gnome FTP File Transfer
  • Liferea Feed Reader
  • Mutt Mail Client
Warranty information
HP Services includes a one-year or three-year standard parts and labor warranty, pick-up or carry-in, and toll-free 7 x 24 hardware technical phone support (depending on model). On-site service and warranty upgrades are also available (depending on model).
For configurations with SuSE Linux Enterprise Desktop 10, HP Services may vary depending on the country of purchase, and toll-free 5 x 8 (Monday through Friday; 9:00am to 5:00pm CST) hardware technical phone support is available.
Country: Flag Vietnam
