    Apache Log4j Update
HP Officejet J6400 and 6500 All-in-One Printer Series - Changing the Language on the HP All-in-One Control Panel Display
This document provides steps to change the language on the product control panel display.
Changing the language on the HP All-in-One display
  1. Press the Setup button.
  2. Press the right arrow button () until Preferences appears on the control panel display, and then press OK.
  3. Press the right arrow button until Set Language & Country/Region appears on the control panel display, and then press OK.
  4. Press the right arrow button until the appropriate language appears on the control panel display.
  5. Press the number keys that correspond to the language on the control panel display.
    If you do not make a selection within five seconds, the control panel display automatically changes to show the next language. If you do not make a selection within two minutes, the setup menu closes, and the settings remain unchanged.
    A confirmation screen appears.
  6. Press the number keys that correspond to Yes to accept the settings, or press the number keys that correspond to No to choose a different language.
  7. After the language is selected, a screen appears for country or region selection. Press the number keys that correspond to the appropriate country or region.
    If you do not make a selection within five seconds, the control panel display automatically changes to show the next country or region. If you do not make a selection within two minutes, the setup menu closes, and the settings remain unchanged.
  8. Press the number keys that correspond to Yes to accept the settings, or press the number keys that correspond to No to choose a different country or region.
