HP iPAQ 310 Travel Companion Series - Content Manager Proxy Settings
Issue:
How is a connection to Content Manager established behind a Proxy Server?
Solution
Changing Proxy Settings within Content Manager
Device must be connected to your computer and Content Manager must have made a connection between the iPAQ unit and the computer.
If you receive ‘No content available’ message, complete the following steps to configure proxy settings:
  1. Select Preferences from the Tools menu.
  2. Select Connection from the Preferences tab.
  3. Move selection from Direct connection to the Internet to Manual proxy configuration.
  4. Type proxy setting into fields to connect to the Internet.
  5. Once setting is entered, click OK. Content Manager re-initializes with the following connection box and checks for updates.
