HP 9200c and 9250c Digital Senders - Hangs After Power ON with No Display, No Error Message, and All Three LED's Continuously Glow
Issue:
The Digital sender hangs after power ON without displaying any error message. Only the three LEDs will be glowing continuously even if it is left for a long time. Turning the power off and then back on again will not help.
Solution
Many times after replacing the formatter, the reinstallation of the memory of the Digital is forgotten. This is the main causes the issue. This issue can be resolved by completing the following steps:
  1. Remove the formatter and make sure the memory is physically present. If not, Install memory and test whether the device comes to the ready mode.
  2. When memory is present, but the issue still persists, remove and reseat the memory and test again.
  3. If the issue still exists, replace the memory with a new one.
Any of the above steps should help resolve the issue.
