22-inch Monitor Specifications - L2245w Model
L2245w Model
L2245w Specifications
Type
55.9 cm wide screen
TFT LCD
22 inches wide screen
Viewable Image Size
55.9 cm diagonal
22–inch diagonal
Tilt
-5 to 35°
Swivel
-45 to 45°
Maximum Weight (Unpacked)
7.6 kg
16.76 lbs.
Dimensions (include base)
Height
Depth
Width
34.5 cm
16.0 cm
53.7 cm
13.58 inches
6.3 inches
21.14 inches
Maximum Graphic Resolution
1680 x 1050 (75 Hz) analog input
1680 x 1050 (75 Hz) digital input)
Optimum Graphic Resolution
1680 x 1050 (60Hz) analog input
1680 x 1050 (60Hz) digital input
Text Mode
720 × 400
Dot Pitch
0.282 (H) × 0.282 (W) mm
Horizontal Frequency
24 to 83 kHz
Vertical Refresh Rate
50 to 76 Hz
Environmental Requirements Temperature
Operating Temperature
Storage Temperature
5 to 40° C
-33 to 60° C
41 to 104° F
-29 to 140° F
Relative Humidity
20 to 80%
Power Source
90 – 265 VAC, 45/63 Hz
Altitude:
Operating
Storage
0 to 3657.6 m
0 to 12192 m
0 to 12,000 feet
0 to 40,000 feet
Power Consumption (maximum)
<65 watts
Input Terminal
One VGA connector with cable included; one DVI connector
Country: Flag Vietnam
