HP iPAQ 200 Enterprise Handheld Series - Personalizing Buttons on your Device
Personalize buttons on your HP iPAQ 200 Enterprise Handheld Series to launch applications of your choice.
You can personalize applications which are present in Start > Programs.
Button
Button 1
Button 3
Button 4
Button 5
You can only personalize buttons 1, 3, 4, and 5 on your device.
Personalizing buttons
Use these steps to personalize the buttons on your device.
  1. Tap Start > Settings > Personal.
  2. Tap the Buttons icon.
    Figure : Accessing the buttons utility
  3. Under Select a button, tap on a button to change its assigned application.
    Figure : Selecting a button
  4. From the Assign a program list, select the program to associate with the button you selected from the previous step.
    The selected program displays as the new Assignment for the button you selected.
  5. Tap ok.
