HP xw8600 Workstation - Spare Parts
Part number and RoHS information
IMPORTANT: Obtaining current part number information
To obtain current part number information for this product, including RoHS-compliant and orderable spare parts, please use one of the following utilities:
Chassis parts
Spare part number
Part description
Base
385529-001
Base mounting assembly with ft
Bezel
336157-001
Floppy drive bezel (Carbonite black plastic) - Includes the drive bezel, light pipe, and disk ejection button
368382-001
Floppy drive bezel assembly (Carbonite black) - Includes the drive bezel, light pipe and disk ejection button
464181-001
Front plastic bezel assembly
Bracket
382864-001
Diskette conversion bracket
Cage
444657-001
Card cage plus system cooling fan assembly
Carrier
464080-001
Hard disk drive carrier - for mounting a notebook 2.5 in form factor drive
Clip
465526-001
Power supply cable retention clips
465620-001
Expansion card support clip
Cover
385521-001
Top access cover panel
Duct
464461-001
Memory modules riser duct assembly
Filler
464463-001
Plastic filler - Memory riser card guide
Panel
385524-001
Access panel - Right side
464182-001
Chassis front I/O control panel assembly
464183-001
Left side panel cover
Plastics kit
417811-001
Miscellaneous plastics kit
Drives
Spare part number
Part description
Drive
390599-001
500GB SATA/300 hard drive - 7200 RPM, 3.5 in form factor, 1.0 in high
392415-001
1.44MB, 3.5 in floppy disk drive without bezel or eject button (carbon black disk door) - Includes the four side mounted guide screws
405427-001
160GB SATA/300 hard drive - 10000 RPM, 3.5 in form factor, 1.0 in high
405429-001
73GB Serial Attached SCSI (SAS) hard drive - 15000 RPM, 3.5 in form factor, 1.0 in high
405430-001
146GB Serial Attached SCSI (SAS) hard drive - 15000 RPM, 3.5 in form factor, 1.0 in high
410411-001
250GB SATA/300 hard drive (Removeable) - 7200 RPM, 3.5 in form factor, 1.0 in high
413647-001
300GB Serial Attached SCSI (SAS) hard drive - 15000 RPM, 3.5 in form factor, 1.0 in high
416327-001
80GB SATA/300 hard drive - 10000 RPM, 3.5 in form factor, 1.0 in high
419496-001
16x SATA DVD-ROM read, 48x-max CD-ROM read - With Black bezel
419497-001
SATA CD-RW/DVD-ROM combo drive - 48X-max CD-R write, 32X-max CD-RW write, 48X-max CD-ROM read, 16X-max DVD-ROM read - Half height drive with carbon black faceplate
447310-001
SATA LightScribe optical drive - DVD+RW at 8X, DVD-R at 16X, DVD-RW at 6X, CD-R at 48X and CD-RW media at 32X
449208-001
146GB Serial Attached SCSI (SAS) hard drive - 10000 RPM, 3.5 in form factor, 1.0 in high
449209-001
73GB Serial Attached SCSI (SAS) hard drive - 10000 RPM, 3.5 in form factor, 1.0 in high
452367-001
80GB SATA/300 hard drive - 7200 RPM, 3.5 in form factor, 1.0 in high
453510-001
1TB SATA hard drive - 7,200 RPM
Electronic accessories
Spare part number
Part description
Mouse
389026-001
USB optical scrolling mouse
444740-001
HP USB optical (Carbon) scroll mouse
Electronic parts
Spare part number
Part description
Adapter
202997-005
DVI-I to VGA adapter - From a (M) DVI-I connector to a (F) 15 pin VGA connector - for connecting a VGA monitor to a DVI-I port on the graphics board
434926-001
Serial Attached SCSI (SAS) to Serial ATA (SATA) hard drive adapter
Cable
392288-001
Floppy diskette drive cable assembly
285380-001
DVI 'Y' adapter cable with Molex DMS-59 connector
393958-001
Serial ATA (SATA) 3G hard drive cable
417817-001
Front panel I/O device cable assembly
430685-001
External mini-SAS cable
446042-001
Cable kit - For internal miniSAS components
447004-001
External cable - For IEEE 1394b device
459916-001
462774-001
Cable assembly - SAS LED cable, 2 pin to 2 pin, 16 in long
464081-001
Power cable - For 2.5 in hard disk drive connection
464462-001
Cable assembly - Memory riser card power cables
464860-001
Cable assembly - For supplying power to the PCIe graphics cards
Fan
430686-001
Tubeaxial fan
464180-001
Rear chassis system and memory fan assembly
Heat sink
462784-001
Processor heat sink and cooling fan assembly
464082-001
Keyboard
435302-001
PS/2 'Windows Vista' keyboard assembly
435382-001
USB 'Windows Vista' keyboard assembly
Memory
419005-001
2.0GB DIMM memory module - PC5300F DDR2-667 MHz, Fully Buffered DIMMs (FBD), ECC 72-bit ECC
419006-001
512MB DIMM memory module - PC5300F DDR2-667 MHz, Fully Buffered DIMMs (FBD), ECC 72-bit ECC
419007-001
1.0GB DIMM memory module - PC5300F DDR2-667 MHz, Fully Buffered DIMMs (FBD), ECC 72-bit ECC
419008-001
4.0GB DIMM memory module - PC5300F DDR2-667 MHz, Fully Buffered DIMMs (FBD), ECC 72-bit ECC
465383-001
System board
440308-001
System board (motherboard) - Does not include processor - supports 1333 MHz front side bus speed (Seaburg)
System board (Audio)
448314-001
SoundBlaster PCIe X-Fi XtremeGamer sound card
System board (Graphics)
390423-001
PCI-Express NVIDIA Quadro NVS 440 graphics board - With 128MB GDDR3 SDRAM, dual 400 MHz RAMDAC - ATX low profile form factor - Requires one PCI-Express slot
442228-001
PCI-Express graphics card - NVIDIA Quadro FX4600, 768MB
456135-001
PCI-Express NVIDIA Quadro FX1700 graphics board - With 512MB memory - Requires one PCI-Express slot
456136-001
PCI-Express NVIDIA Quadro FX370 graphics board - With 256MB memory - Requires one PCI-Express slot
456137-001
NVIDIA Quadro NVS 290 PCI-Express graphics card - Low profile graphics board with 256MB DDR2 SDRAM, one DMS-59 high density output connector - Maximum of two displays per board
456138-001
PCI-Express NVIDIA Quadro FX570 graphics board - With 256MB memory - Requires one PCI-Express slot
456139-001
PCIe Nvidia Quadro FX5600 graphics card - Has 1.5GB frame buffer rate, DVI-I ports, and 128-bit graphics processor data width - External resolution 3840 x 2400 (max)
456959-001
ATI FireGL V5600 PCI Express (PCIe) graphics card- With 512MB memory - Requires one PCI-Express slot
462790-001
PCIe Nvidia Quadro FX 3700 graphics accelerator card - With 512MB memory
System board (Interface)
202997-001
DVI-I to VGA adapter - From a (M) DVI-I connector to a (F) 15 pin VGA connector - For connecting a VGA monitor to a DVI-I port on the graphics board
398400-001
HP FireWire IEEE 1394b 3-Port PCI card
430654-001
HP Broadcom PCI Ethernet Lan adapter
441448-001
HP FireWire IEEE 1394a 3-Port PCI interface card
444361-001
Memory module riser circuit board
448317-001
LSI 8888 ELP 8 Port SAS HW RAID Card
Power supply
442038-001
1050 W custom power supply. Wide ranging, active power factor corrected - ENERGY STAR 4.0 and 80 Plus compliant - Has a second PCI Express auxilliary connector
444411-001
800 W custom power supply. Wide ranging, active power factor corrected - ENERGY STAR 4.0 and 80 Plus compliant - Has a second PCI Express auxilliary connector
Processor
462775-001
Intel Xeon dual-core processor 5205 - 1.86 GHz (Wolfdale, 1066-MHz front side bus, 6MB Level-2 cache, socket 775, based on the 45nm Penryn process)
462776-001
Intel Xeon dual-core processor 5240 - 3.16 Hz (Wolfdale, 1333-MHz front side bus, MB Level-2 cache, socket 775, based on the 45nm Penryn process)
462777-001
Intel Xeon dual-core processor 5260 - 3.33 GHz (Wolfdale, 1333-MHz front side bus, 6MB Level-2 cache, socket 775, based on the 45nm Penryn process)
462778-001
Intel Xeon processor 5405 - 3.33 GHz (Harpertown, 1333-MHz front side bus, 12MB Level-2 cache, socket 775, based on the 45nm Penryn process)
462779-001
Intel Xeon processor 5410 - 2.33 GHz (Harpertown, 1333-MHz front side bus, 12MB Level-2 cache, socket 775, based on the 45nm Penryn process)
462780-001
Intel Xeon processor 5420 - 2.50 GHz (Harpertown, 1333-MHz front side bus, 12MB Level-2 cache, socket 775, based on the 45nm Penryn process)
462781-001
Intel Xeon processor 5430 - 2.66 GHz (Harpertown, 1333-MHz front side bus, 12MB Level-2 cache, socket 775, based on the 45nm Penryn process)
462782-001
Intel Xeon processor 5440 - 2.83 GHz (Harpertown, 1333-MHz front side bus, 12MB Level-2 cache, socket 775, based on the 45nm Penryn process)
464076-001
Intel Xeon processor 5440 - 3.0 GHz (Harpertown, 1333-MHz front side bus, 12MB Level-2 cache, socket 775, based on the 45nm Penryn process)
464077-001
Intel Xeon processor 5440 - 3.16 GHz (Harpertown, 1333-MHz front side bus, 12MB Level-2 cache, socket 775, based on the 45nm Penryn process)
501701-001
Intel Xeon X5470 3.33 12 MB/1333 QC CPU-2
Support
440648-001
/O PC card support
