HP xw4600 Workstation - Spare Parts
Part number and RoHS information
IMPORTANT: Obtaining current part number information
To obtain current part number information for this product, including RoHS-compliant and orderable spare parts, please use one of the following utilities:
  • Click here to go to HP PartSurfer. (To report missing or incorrect parts information in PartSurfer, please use the "Contact us" and "Missing or incorrect data" links within the utility.)
    To lookup RoHS-compliant information in PartSurfer, use the component’s option part number or the sales order number for a system in which the component is used (available in the QuickSpecs or Standard Models page). The spare part number does not provide RoHS-compliant information.
  • To lookup part numbers by the sales SKU number click on "Exploded to Spare" or to lookup part numbers by the spare part number click on the link to "lookup by spare".
Chassis parts
Spare part number
Part description
336157-001
Floppy drive bezel (Carbonite black plastic)
460288-001
Front bezel assembly
444873-001
HP removable SATA hard drive enclosure
392289-001
Floppy drive bezel blank replacement
335937-001
Drive bay bezel filler (Carbon) - for 5.25 inches devices
444872-001
HP removable SATA hard drive enclosure (frame and carrier)
460287-001
Side access panel
435227-001
Miscellaneous hardware kit - Includes plastic hard drive mounting rails, DD isolation rail, silver matte round feet, and various screws
392416-001
Solenoid security lock
Drives
Spare part number
Part description
390599-001
500GB SATA/300 hard drive 7200 RPM, 3.5 inches form factor, 1 inch high
392415-001
1.44MB, 3.5 inches floppy disk drive without bezel or eject button
405427-001
160GB SATA/300 hard drive 10000 RPM, 3.5 inches form factor, 1 inch high
405429-001
73GB Serial Attached SCSI (SAS) hard drive 15000 RPM, 3.5 inches form factor, 1 inch high
405430-001
146GB Serial Attached SCSI (SAS) hard drive 15000 RPM, 3.5 inches form factor, 1 inch high
410411-001
250GB SATA/300 hard drive (Removeable) 7200 RPM, 3.5 inches form factor, 1 inch high
413647-001
300GB Serial Attached SCSI (SAS) hard drive 15000 RPM, 3.5 inches form factor, 1 inch high
416327-001
80GB SATA/300 hard drive 10000 RPM, 3.5 inches form factor, 1 inch high
419496-001
16x SATA DVD-ROM read, 48x-max CD-ROM read - With Black bezel
419497-001
SATA CD-RW/DVD-ROM combo drive
447310-001
SATA LightScribe optical drive
452367-001
80GB SATA/300 hard drive 7200 RPM, 3.5 inches form factor, 1 inch high
453139-001
160GB SATA/300 hard drive 7200 RPM, 3.5 inches form factor, 1 inch high
Electronic parts
Spare part number
Part description
Adapter
202997-005
DVI-I to VGA adapter
434926-001
Serial Attached SCSI (SAS) to Serial ATA (SATA) hard drive adapter
Cable
392288-001
Floppy diskette drive cable assembly
285380-001
DVI 'Y' adapter cable with Molex DMS-59 connector
391739-001
Serial ATA (SATA) 3G hard drive cable
415949-001
SCSI LED cable assembly
432219-001
Front panel I/O cable
447004-001
External cable - For IEEE 1394b device
459916-001
460577-001
Power LED and thermal sensor
Fan
434645-001
Chassis cooling fan
460285-001
Processor heatsink and fan assembly
Keyboard
435302-001
PS/2 keyboard assembly
435382-001
USB keyboard assembly
Memory
392280-001
512MB SDRAM DIMM memory module - PC2 5300 DDR2-667 MHz, ECC unbuffered
392283-001
1GB SDRAM DIMM memory module - PC2 5300 DDR2-667 MHz, ECC unbuffered
459340-001
1GB SDRAM DIMM memory module - PC2 6400E DDR2-800 MHz, ECC unbuffered
459341-001
512MB SDRAM DIMM memory module - PC2 6400E DDR2-800 MHz, ECC unbuffered
460277-001
2GB SDRAM DIMM memory module - PC2 6400E DDR2-800 MHz, ECC unbuffered
Mouse
389026-001
USB optical scrolling mouse
444740-001
HP USB optical scroll mouse
System board
441449-001
Intel X38 express chipset, 1333 MHz Front Side Bus
448314-001
SoundBlaster PCIe X-Fi XtremeGamer sound card
390423-001
PCI-Express NVIDIA Quadro NVS 440 graphics board - With 128MB GDDR3 SDRAM, dual 400 MHz RAMDAC - ATX low profile form factor
413110-001
PCI-Express NVIDIA Quadro FX3500 graphics board - With 256MB GDDR3 SDRAM, dual 400 MHz RAMDAC - ATX form factor
442228-001
PCI-Express graphics card - NVIDIA Quadro FX4600, 768MB
456135-001
PCI-Express NVIDIA Quadro FX1700 graphics board - With 512MB memory - Requires one PCI-Express slot
456136-001
PCI-Express NVIDIA Quadro FX370 graphics board - With 256MB memory - Requires one PCI-Express slot
456137-001
NVIDIA Quadro NVS 290 PCI-Express graphics card - Low profile graphics board with 256MB DDR2 SDRAM, one DMS-59 high density output connector
456138-001
PCI-Express NVIDIA Quadro FX570 graphics board - With 256MB memory - Requires one PCI-Express slot
456959-001
ATI FireGL V5600 PCI Express (PCIe) graphics card- With 512MB memory - Requires one PCI-Express slot
202997-001
DVI-I to VGA adapter - From a (M) DVI-I connector to a (F) 15-pin VGA connector
393308-001
HP FireWire IEEE 1394a 3-Port PCI card
398400-001
HP FireWire IEEE 1394b 3-Port PCI card
430654-001
HP Broadcom PCI Ethernet Lan adapter
Power
452554-001
Power supply
Processor
449452-001
Intel Core 2 Duo processor E4500 - 2.2 GHz
450694-001
Intel Core 2 Duo processor E6550 - 2.33 GHz
450791-001
Intel Core 2 Duo processor E6750 - 2.6 GHz
450792-001
Intel Core 2 Duo processor E6850 - 3.0 GHz
452451-001
Intel Core 2 Quad processor Q6600 - 2.4 GHz
497734-001
Intel Xeon Quad-Core processor Q9650 - 3.0GHz
457656-001
Intel Pentium Dual-Core processor E2180 - 2.0 GHz
509554-001
Intel Core 2 Duo E8400 processor - 3.0GHz (1333 MHz front side bus, 6MB Level-2 cache, 65 W TDP, socket LGA775)
Card reader
412838-001
Media card reader
Speaker
392413-001
Speaker assembly
Switch
392417-001
Hood (smart cover) sensor switch
