HP Personal Workstation - Starting the HP Insight Diagnostics Utility from CD
HP Insight Diagnostics is available on the Documentation & Diagnostic CD that was shipped with the workstation.
Details
To start the diagnostic utility on the Documentation & Diagnostic CD:
  1. Power on the workstation, and press the F10 key during the initial boot process to enter the Computer Setup (F10) Utility.
  2. Select your language from the list, and press the Enter key. In the Computer Setup Utilities menu, four headings are displayed: File, Storage, Security, and Advanced. Other headings might be displayed, depending on the workstation.
  3. Use the right arrow key to select Storage.
  4. Use the down arrow key to select Boot Order, and press Enter.
  5. Select CD-ROM Drive, and enable it as a bootable device by pressing the F5 key (if not already enabled, pressing the F5 key again disables the device). The default setting is enabled.
  6. Set the CD-ROM Drive to the top of the boot order. Select CD-ROM, press the Enter key, and use the up arrow to move it to the top of the boot order.
  7. To apply and save changes, press the F10 key, and select File>Save Changes and Exit.
  8. Insert the Documentation & Diagnostic CD into the workstation.
  9. Restart your system, HP Insight Diagnostics launches automatically.
