    Fix Windows 10 Update Issues
HP iPAQ Pocket PCs - Identify the Version of the .NET Compact Framework
To identify the version of the .NET Compact Framework installed on the iPAQ.
Details
To identify the version of .NET Compact Framework installed on the iPAQ, browse to File Explorer > My Device | Windows and click the executable cgacutil.
This will display the version similar to this one: Microsoft .NET Compact Framework [1.0.4292.00].
The following list will tell you which version of the Compact Framework is installed on the device:
CF1.0 RTM = 1.0.2268.0CF1.0 SP1 = 1.0.3111.0CF1.0 SP2 Recall = 1.0.3226.0CF1.0 SP2 Beta = 1.0.3227.0CF1.0 SP2 Final = 1.0.3316.0CF1.0 SP3 = 1.0.4292.00CF2.0 RTM = 2.xx
