HP iPAQ 200 Enterprise Handheld Series - Product Specifications
System specifications
System Feature
Processor
Marvell PXA310, 624 MHz
Processor numbering is not a measurement of higher performance.
Operating System
Microsoft® Mobile® 6 Classic Edition
Memory
128 MB SDRAM main memory for running applications. 256 MB flash ROM
External Power
AC Input: 100~240 Vac, 50/60 Hz AC Input current: 0.5 Aac max Output Voltage: 5.2Vdc (typical), Output Current: 2A (typical)
4-inch VGA 640 x 480 TFT with touch screen, 18-bit, portrait oriented
Expansion
SDIO and CF card slots
Audio
Headphone jack: 3.5mm 4 pin support for stereo or VoIP headset. One speaker, one receiver, one microphone, positioned for VoIP
Battery
Removable/rechargeable 2200 mAh Lithium Ion battery
Battery run time varies based on the usage pattern and the configuration of the handheld. Use of internal wireless capabilities and backlight will significantly decrease battery run time.
Bluetooth® Specifications
Technology: High-speed, low-power, short-range wireless communication with other Bluetooth devices
Specification: Bluetooth 2.0 with EDR (2.4 GHz Industrial Scientific Medical Band)
System interface: UART
Device type: Class 2; up to 4 dBm transmit, typical 10 meter range
Power:
  • Typical TX current at approximately 56 mA
  • Typical RX current at approximately 45 mA
Wireless LAN Specifications
IEEE standard(s): 802.11 b/g
Frequency band: 2.4000 to 2.97 GHz
Antenna type: PIFA Antenna
Modulation technique: 802.11b CCK Mode3, 802.11g OFDM
Receiver sensitivity – packet error rate: 1 Mbps: <-93 dBm, PER < 8%, typical
Transmit output power:
  • 11 Mbps: <-87 dBm, PER < 8%, typical
  • 54 Mbps: <-72 dBm, PER < 10%, typical
  • 14.0 dBm (typical 802.11b), 12 dBm (typical 802.11x)
Power consumption:
  • Transmit mode: 0.99 Watts, typical
  • Receive mode: 0.99 Watts, typical
Operating distance: Up to 300 feet – open sight
Indicators
Alarms:
  • Solid amber power button – battery charging
  • Solid green power button – battery fully charged
  • Flashing blue LED – WLAN and/or Bluetooth active
Notification: Sound and visual message on the display
Connectors/ Interface(s)
24-pin connector, Mini USB
Hardware Buttons
9-way navigation with press to activate; 4 programmable keys; voice recorder, power, and reset buttons
Physical specifications
US
Metric
Height
4.96 in
126 mm
Width
2.99 in
76 mm
Depth
0.63 in
16 mm
6.8 oz
192 g
Operating environment
US
Metric
Operating Temperature
41° to 113° F
5° to 45° C
Storage Temperature
–4° to 140° F
–20° to 60° C
Operating Humidity
30~85% Relative Humidity
