    Fix HP Printer issue on macOS
HP Handheld sp400 Series All-in-One Scanner Printer - Removing the Hand Mount or Handle Accessory
  1. Squeeze both of the release buttons on the back of the hand mount.
  2. Slide the hand mount backward, off of the All-in-One.
    Figure : Slide hand mount backward
  1. Release button
IMPORTANT: If you are using the handle accessory instead of the hand mount, see the instructions that were included with the handle accessory.
