    Fix HP Printer issue on macOS
HP iPAQ 100 Classic Handheld Series - Device Freezes Up All the Time
Issue
The HP iPAQ 100 Classic Handheld Series device freezes up all the time.
Solution
Programs may be running in the background. Stop these programs to free up running memory.
Follow these steps to stop all background programs.
  1. On the Today screen, tap Start > Settings.
  2. From the System tab, tap Memory.
  3. On the Running Programs tab, tap Stop All.
  4. Tap OK.
Stopping running programs only stops the programs from running in the background. It does not disable the program. Running programs in the background also contributes to fast battery drain.
Additional Information
Check these documents on www.hp.com/support for more information:
  • HP iPAQ 100 Classic Handheld Series – Installing and Removing Programs/Applications
  • HP iPAQ 100 Classic Handheld Series – Battery Saving Tips
  • HP iPAQ 100 Classic Handheld Series – Resetting the Device
  • HP iPAQ 110 Classic Handheld Series – Using and Troubleshooting the Device Using Emulators
You can also check the softpaq - HP iPAQ 100 Classic Handheld Series - English ROM Update for more details.
