    Looking for Site Help?
HP LaserJet M1522 MFP Series Product - Fax alert and warning messages
Control panel message
Recommended action
Comm. error
A fax communication error occurred between the product and the sender or receiver.
Allow the product to retry sending the fax. Unplug the product telephone cord from the wall, plug in a telephone, and try making a call. Plug the product phone cord into a jack for another phone line.
Try a different phone cord.
If the error persists, contact HP. See www.hp.com/support/ljm1522 or the support flyer that came in the product box.
Fax delayed – Send memory full
Fax memory is full.
Cancel the fax by pressing OK or Cancel. Resend the fax. You might need to send the fax in multiple sections if the error occurs again.
Fax is busy Canceled send
The fax line to which you were sending a fax was busy. The product has canceled sending the fax.
Call the recipient to ensure that the fax machine is on and ready.
Check that you are dialing the correct fax number.
Check that the Redial if busy option is enabled.
Check for a dial tone on the phone line by pressing Start Fax.
Make sure that the phone is working by disconnecting the product, plugging in a telephone to the phone line, and making a voice call.
Plug the product phone cord into a jack for another phone line, and then try sending the fax again.
Fax is busy Redial pending
The fax line to which you were sending a fax was busy. The product automatically redials the busy number. See Set autoredial.
Plug the product phone cord into a jack for another phone line, and try sending the fax again.
Fax memory full Canceling recv.
During the fax transmission, the product ran out of memory. Only the pages that fit into memory will be printed.
Print all of the faxes, and then have the sender resend the fax. Have the sender divide the fax job into multiple jobs before resending. Cancel all fax jobs or clear the faxes from memory.
If the problem persists, restore factory defaults and upgrade the product firmware.
Adding a memory DIMM does not help resolve this issue.
Fax memory full Canceling send
During the fax job, the memory filled. All pages of the fax have to be in memory for a fax job to work correctly. Only the pages that fit into memory were sent.
Print all received faxes or wait until all pending faxes are sent.
Ask the sender to send the fax again.
Fax recv. error
An error occurred while trying to receive a fax.
Ask the sender to resend the fax.
Try faxing back to the sender or another fax machine.
Check that the telephone cord is securely connected by unplugging and replugging the cord.
Make sure that you are using the telephone cord that came with the product.
Decrease the fax speed. Ask the sender to resend the fax.
Turn off error-correction mode. Ask the sender to resend the fax.
Connect the product to a different phone line.
Fax Send error
An error occurred while trying to send a fax.
Try resending the fax.
Try faxing to another fax number.
Set the fax resolution to Standard instead of the default of Fine.
Group dial not allowed in group
The speed-dial code that you typed is programmed for a group. Adding a group-dial to another group-dial is not allowed.
Add one-touch buttons (programmed as an individual speed dial) or speed-dial codes to a group-dial.
Invalid entry
Invalid data or response.
Correct the entry.
No Dial Tone
The product could not detect a dial tone.
Unplug the telephone cord from both the product and the wall and replug the cord.
Unplug the product telephone cord from the wall, plug in a telephone, and try making a voice call.
No document sent
The product did not scan any pages, or it did not receive any pages from the computer to transmit a fax.
Try sending the fax again.
No fax answer Redial pending
The receiving fax line did not answer. The product attempts to redial after a few minutes.
If the product continues to redial, unplug the product telephone cord from the wall, plug in a telephone, and try making a voice call.
No fax answer. Canceled send
Attempts to redial a fax number failed, or the “Redial-no answer” option was turned off.
Check that the redial option is enabled.
No fax detected
The product answered the incoming call but did not detect that a fax machine was calling.
Allow the product to retry receiving the fax.
Country: Flag Vietnam
