Opening the PC Case in Compaq Presario SR5000 Series PCs
This document pertains only to HP desktop computers with the following computer case (your case might appear slightly different):
Before you begin
  • Turn off the computer, disconnect all cables, and transfer the computer to a clear, flat, stable work surface over a non-carpeted floor. Disconnect the modem cable before you disconnect the power cord.
  warning:
This product contains components that can be damaged by electrostatic discharge (ESD). To reduce the chance of ESD damage, work over a non-carpeted floor, use a static dissipative work surface (such as a conductive foam pad), and wear an ESD wrist strap connected to a grounded surface.
Video overview
View the following video before using the steps in this document.
Removing the side panel
To access most components, remove the side panel.
  warning:
Step 1. With all cables disconnected from the computer, loosen the thumb screw that connects the side panel to the computer case.
Step 2. Grasp the handle on the panel, and pull toward the back of the computer.
Step 3. Remove the panel from the computer system.
The right side panel is now removed, providing access to the parts inside the PC.
Replacing the side panel
Before replacing, be sure all components have been connected inside the computer.
The side panel has several interior tabs on its top, bottom, and leading edges.
These tabs fit into corresponding slots over the front edge of the computer.
Step 1. To reattach the panel, align the tabs on the panel over the slots on the computer and lay the panel in place.
Step 2. Slide the panel forward to lock it into position.
Step 3. Reattach the thumb screw.
