    We are upgrading our website
HP Scanjet - How Do I Find My Model Number?
Issue
How do I find the model number of my HP Scanjet scanner?
Solution
Use one of the methods described below to identify your HP Scanjet scanner.
Method one: Locate the number on the top of the scanner in the center
Find the model number on the top of the HP Scanjet scanner. If this method does not work, try one of the other methods.
Figure : Lid of the scanner
Method two: Locate number on the bottom of the scanner
Find the series number on the bottom of the HP Scanjet scanner. If this method does not work, try one of the other methods.
Figure : Label under the scanner
The HP Scanjet scanners are grouped as a series. A series of scanner have the same main scanning unit and scanning software. The different models within a series refers to accessories and bonus software.
Method three: Locate number on the bottom of the scanner and then locate the number in the table below
Find the product number on the back or bottom of the scanner and then find the correlating HP Scanjet model number from the table shown below.
The product number may be written on a label or molded into the plastic. Some scanners use the same scanning base; therefore, different scanner models may have the same product number.
Figure : Label on the bottom of the scanner
Model number
L1945A
L1970A
L1950A
L1952A
L1920A
Q3871A
Q2950A
Q3840A
C7720A
C7722A
C7723A
Q2800A
Q2700A
Q2703A
Q3851A
Q3853A
L1915A
Q3192A
Q3190A
C9917A
C9913A
C9927A
C9923A
Q3112A
L1925A
Q3113A
Q3122A
L1930A
Q3123A
L1935A
C9929A
C9928A
C9919A
C9918A
L1910A
L1912A
L1983A
L1940A
L1942A
C9931A
C9934A
C9932A
C9933A
L1985A
L1956A
L1957A
Q3110A
Q3120A
Q3870A
L1941A
C9924A
C9928V
C9929V
C9927V
Country: Flag Vietnam
