HP iPAQ 300 Travel Companion Series - Navigating to an Address/Destination
Using the pre-loaded GPS software on your iPAQ, you can calculate routes and navigate to a desired destination.
To navigate to an address:
  1. If you are not on the Main menu screen, tap to return.
    Figure : Main Menu Screen
  2. Tap the icon. This will take you to the Navigation main menu screen.
    Figure : Navigation Menu Screen
  3. Tap Go to.
  4. Tap Address.
  5. The first two lines show the country and region/state of the last search.
  6. If the address is in a different country, tap the icon with the name of the country, and select the desired country from a list.
  7. If the appropriate country is displayed, and you need to change the region/state to search for, either
    1. tap History to select a recently used region/state; or
    2. tap the icon with the region/state, and enter the desired city or town.
  8. With country and region/state selected, you have two options:
    1. tap City Center to navigate to the centre of the region/state; or
    2. tap Enter Street Name and enter the street you are looking for.
  9. With country, region/state and street selected, there are three options to finish the address search:
    1. tap Street Center to navigate to the midpoint of the street;
    2. tap Intersection and enter the name of the crossing street; or
    3. tap House Number and enter the house number to navigate to.
  10. If any of the above three is chosen, the map is displayed with the selected point in the middle, and the Cursor menu displays your available options.
  11. Tap Set as Destination.
  12. The route is automatically planned, and navigation starts.
  13. Start driving, and listen to the voice instructions of the Travel Companion.
