    Fix HP Printer issue on macOS
HP iPAQ 300 Travel Companion Series - Using the Multi-function Wheel
The multi-function wheel is located on the side of the device as shown in the following graphic. While the exact functionality of the multi-function wheel is specific to the current application in use, it does provide some general functions:
  • Use the multi-function wheel to scroll up or down on a screen, or increase or decrease the audio volume. When using the navigation software, turn the wheel up to zoom in, and turn it down to zoom out.
    Figure : Using the Multi-function Wheel
  • Press the multi-function wheel once to select an item on the screen.
  • Press and hold the multi-function wheel to obtain a 'short cuts' menu specific to the current screen.
    Figure : Shortscuts Menu
    Move the wheel up or down to scroll through the list, and press it to select the highlighted subsystem. Press and hold the wheel again, or wait for a few seconds, to close the menu.
