HP Designjet T1100 and T1120 MFP Series Products - Set Date and Time
Set date and time
The date and time can be set so they will be known by the program. Setting the date and time is relevant for accounting.
  1. Press the Setup tab.Setup tab
  2. Press Options, System.
  3. Press the Set Time and Date button.
  4. Start with the Time Zone setting. Press the Time zone button and select the time zone for your area.
  5. For convenience, you can select automatic daylight savings time adjustment.
  6. With the local time zone selected, set the current date and time. Press each value button to make a setting. You will need your keyboard to set values.
