HP Designjet T1100 and T1120 MFP Series Products - Printer Setup in Scanning System Software
Printer setup in scanning system software
You should not normally need to use this procedure as this part of printer setup is automatic when you install the printer for the first time.
Follow this procedure only if no printer is available in your Setup tab or for controlling correct printer installation.
  1. Select the Setup tab. Setup tab
  2. Select the Printer button.
  3. Select the Tool button and then the Printer Setup button. Printer Setup
  4. Check the Printer profile radio button in the formatting part of the window. Print dialog
  5. Select OK to finish.
