HP Designjet T1100 and T1120 MFP Series Products - WIDEsystem
WIDEsystem
WIDEsystem is an application designed to monitor and control the functionality of your scanner and contains the drivers required by your system.
To reach WIDEsystem Setup tab, Options, System, WIDEsystem
The programs main features are:
System Status
  • View the scanner system's status, called the Scanner Mode, by exiting your scanner system and on the Active Desktop, selecting the WIDEsystem scanner icon on the system tray. Status messages include remaining warm-up time, interface connection errors, and an indication that the scanner is ready for scanning.
  • View useful error messages that relate to the current Scanner Mode.
  • View the load status of the original (media) to be scanned.
System Timer
Set up the scanner system's timer to determine times for automatic power-up and power-down each day of the week. Optimum performance from your scanner is obtained when it has warmed up for an hour (may vary according to your working environment). Also, if you are printing from lists and there are a large number of copies, you may want to leave your system running in overnight or at weekends. When the power off time is reached, the scanner is set to standby mode (power light is red) and the WIDEsystem icon on your Active Desktop is yellow.
If a scan is being done when power off time is reached, automatic power off is delayed by 15 minutes. If the scanner is manually started, 3 hours will have to pass before it goes into standby.
Scanner Information
  • View information on the scanner system's firmware and hardware revisions. The information helps you keep track of your upgrades and is useful for support purposes.
  • Initiate a scan of the SCSI or USB interface bus.
Share your scanner
  • Select the Share your current scanner... option to allow other users on the network to use you scanner from their workstations.
