HP Scanjet G2710 Photo Scanner - Change scan settings
You can change many scan settings from the HP Solution Center, including:
  • Button settings for the scanner front panel
  • Settings for the HP Solution Center scan buttons
  • Scan preferences, such as automatic exposure
To view or change the scan settings, open the HP Solution Center and select the device. Click Settings, point to Scan Settings, and then select the type of settings you want to view or change. To get help with settings, click Help.
