HP iPAQ 100 Classic Handheld Series - Different Ways Of Entering Text
Based on your preference, you can use the on-screen keyboard or a handwriting recognition feature such as Block Recognizer, Keyboard Letter Recognizer, or Transcriber to enter text.
  1. Tap Start > Settings > Personal > Input.
  2. On the Input Method tab, select a text input method and change options as appropriate.
    Figure : Input Methods Available
  3. Tap ok.
You can now go to a program (such as Notes) and start entering text.
Text-Input Method
Definition
Block Recognizer
Use a single stroke to write letters, numbers, symbols, and punctuation marks that get converted into typed text.
Figure : Entering text using Block Recognizer
Keyboard
Tap keys on the keyboard to enter text.
Figure : Entering text using the onscreen Keyboard
Letter Recognizer
Write individual letters, numbers, and punctuation marks that are converted into typed text.
Figure : Entering text using Letter Recognizer
Transcriber
Write in cursive, print, or mixed handwriting (consisting of both cursive and print), and convert your writing into typed text.
Figure : Text written using Transcriber Method
Figure : The above text after being transcribed
Change the text input method from within any program by tapping the Input Selector arrow and selecting an input method.
