    Fix HP Printer issue on macOS
HP Officejet J3600 All-in-One Series - Description of the External Parts of the Printer
Use the images and tables below to identify the components and external parts of the HP OJ J3600 AiO series.
Front of the All-in-One
Figure : Front view of the HP Officejet
Number
Component
1
Document feeder tray.
2
Control panel display.
3
Paper guides.
4
Control panel.
5
Print cartridge door.
6
Input tray.
7
Tray extender.
8
Paper-width guide.
9
Document catcher.
10
Document catcher extender.
11
Handset.
Printing supplies area
Figure : Area for printing supplies
Number
Component
1
2
Print cartridges.
Control panel buttons and lights overview
The following diagram and related table provide a quick reference to the control panel features.
Figure : Control panel buttons and lights overview of the HP Officejet AiO
Number
Name
1
Speed Dial
Selects a speed dial number.
2
Redial/Pause
Redials the most recently dialed number or inserts a 3-second pause in a fax number.
3
Lighter / Darker
Lightens or darkens black-and-white faxes being sent.
4
Fax Resolution
Adjusts the resolution for black-and-white faxes being sent.
5
On light
Indicates, when lighted, that the HP All-in-One is on. The light blinks when the HP All-in-One is performing a task.
6
Attention light
When blinking, the attention light indicates an error has occurred that requires your attention.
7
View menus and messages.
8
Auto Answer
Switches among the Answer Mode settings. Depending on the setting, the HP All-in-One automatically answers incoming phone calls, requires you to receive the fax manually, or "listens" for fax tones.
9
Flash
Cancels a fax and brings up a dial tone. Also used for call waiting.
10
Setup
Presents the Setup Menu for generating reports, changing fax and other maintenance settings, and accessing the Help menu. Press() to scroll through the Help topics available, and then press OK to select a topic. The Help topic you select opens on your computer screen.
11
Fax Menu
Places the HP All-in-One in fax mode and presents the Fax Menu. Press Fax Menu repeatedly to scroll through the options in the Fax Menu.
12
Scan To
Places the HP All-in-One in scan mode and presents the Scan To menu for selecting a scan destination.
13
Copy Menu
Places the HP All-in-One in copy mode and presents the Copy Menu. Press Copy Menu repeatedly to scroll through the options in the Copy Menu.
14
Start Black
Start Color
Starts a black-and-white copy, scan, or fax job.
Starts a color copy, scan, or fax job.
Cancel
Stops a job, exits a menu, or exits settings.
16
Right arrow
Increases values on the display.
17
OK
Selects a menu or a setting on the display.
18
Left arrow
Decrease values on the display.
19
Power
Turns the HP All-in-One on or off. The On light next to the Power button is lit when the HP All-in-One is on. The light blinks while performing a job.
When the HP All-in-One is off, a minimal amount of power is still supplied to the device. To completely disconnect the power supply to the HP All-in-One, turn the device off, and then unplug the power cord.
20
Keypad
Enter fax numbers, values, or text.
21
One-touch speed dial buttons
Accesses the first ten speed dial numbers. Press a speed dial button once to select the speed dial number presented in the left column. Press the same speed dial button a second time to select the speed dial number in the right column.
Back of the All-in-One
Figure : Back view of the HP Officejet
Number
Component
1
Power connection.
2
Rear universal serial bus (USB) port.
3
Fax ports (1-LINE and 2-EXT).
4
Rear door.
5
Rear door access tab.
