    Windows 11 Upgrade Guide
HP Officejet J3600 All-in-One Printer Series- Setting up the All-in-One (Hardware)
  • Unpack the All-in-One
  • Unfold the paper trays
  • Attach the control panel faceplate, if not attached
  • Load plain white paper
  • Connect the power cord and adapter
  • Turn the All-in-One on
  • Select the language and country/region
  • Set the date and time
  • Install the cartridges
  • Align the cartridges
Follow these steps in order.
  1. Remove the tape from the outside of the product, and then open it. Be sure to remove and discard the orange shipping lock.
  2. Pull down the paper tray. Remove the packing material from the inside of the product, including the packing material around the carriage that holds the cartridges.
    Figure : Pull down the paper tray
    Pull down the paper tray and remove packing material
Step three: Unfold the paper trays
  1. Raise the document feeder tray on top of the product, and then open out the lower tray extender.
    Figure : Open feeder tray and tray extender
    Lift up the top document feeder and pull out the lower tray extender
  2. Open out the document catcher.
    Figure : Open document catcher
    Open the document catcher tray toward the front
Step four: Attach the control panel faceplate, if not attached
  1. Fit the faceplate tabs into the slots on top of the product.
    Figure : Install control panel faceplate
    Align the control panel faceplate tabs on top of the product
  2. Rotate the faceplate down, and then firmly press down on the front corners until they both snap into place.
    Figure : Snap the faceplate into place
    Press down firmly on the front corners of the faceplate
Make sure that all edges are even with the product, and that all buttons come through the holes in the faceplate. The control panel faceplate must be attached for the product to work.
Step five: Load plain white paper
Follow these steps to load plain paper.
  1. Raise the document catcher.
  2. Slide the paper-width guide to its outermost position.
    Figure : Slide out paper-width guide
    In the paper tray, slide the paper width guide all the way to the left
  3. Tap a stack of paper on a flat surface to align the edges, and then check the paper for the following:
    • Make sure it is free of rips, dust, wrinkles, and curled or bent edges.
    • Make sure all the paper in the stack is the same size and type.
  4. Insert the stack of paper into the input tray with the short edge forward and the print side down. Slide the stack of paper forward until it stops.
    Figure : Insert paper
    Load the stack of paper into the paper tray
    Make sure that the product is idle and silent when you load paper into the input tray. If the product is servicing the cartridges or otherwise engaged in a task, the paper stop inside the device might not be in place. You could push the paper too far forward, causing the product to eject blank pages.
    If you are using letterhead, insert the top of the page first with the print side down. For more help on loading full-size paper and letterhead, refer to the diagram engraved in the base of the input tray.
  5. Slide the paper-width guide inward until it stops at the edge of the paper. Do not overload the input tray; make sure the stack of paper fits within the input tray and is no higher than the top of the paper-width guide.
  6. Lower the document catcher.
Step six: Connect the power cord and adapter
  1. Plug the product end of the power adapter into the back of the product.
  2. Plug the adapter end of the power cord into the power adapter.
  3. Plug the remaining end of the power cord into a grounded wall outlet or surge protector.
Figure : Connect power cord and adapter
Connect the power cords
Step seven: Turn the All-in-One on
Press the Power button to turn the product on.
Figure : Turn on the product
Press the power button to turn the product on
Step eight: Select the language and country/region
Follow these steps to select the language and country/region.
Select the language
  1. Press Setup.
  2. Use the Arrow buttons () to scroll to the Preferences menu on the display, and then press OK.
  3. Use the Right arrow button () to select Language, and then press OK.
  4. Use the Right arrow ( ) button to select the desired language, and then press OK.
Follow these steps to select the country/region.
Select the Country/Region
  1. Press Setup.
  3. Use the Right arrow button () to select Country/Region, and then press OK.
  4. Use the Right arrow button () to select the desired Country/Region, and then press OK.
Step nine: Set the date and time
  1. Press Setup.
  2. Use the Arrow buttons to scroll to the Tools menu on the display, and then press OK.
  3. Use right arrow () to select Date and Time, and then press OK .
  4. Follow the prompts to enter the date and time, and then press OK.
Step ten: Install the cartridges
Leave the product turned on to install the cartridges.
Follow these steps to install the cartridges.
  1. Open the cartridge door.
    The carriage moves to the far right side of the product.
    Figure : Open the cartridge door
    On the right side of the product, raise the cartridge door
  2. Remove the new cartridge from its packaging and, being careful to touch only the black plastic, gently remove the plastic tape by using the pink pull tab.
      Figure : Remove tape from cartridge
      Remove protective tape from the cartridges
    1. Copper-colored contacts
    2. Plastic tape with pink pull tab (must be removed before installing)
    3. Ink nozzles under tape
    Do not touch the cartridge ink nozzles or copper contacts. Touching these parts will result in clogs, ink failure, and bad electrical connections. Do not remove the copper strips. They are required electrical contacts.
    Figure : Do not touch the ink nozzles or copper contacts.
    Do not touch the nozzles or electrical contacts with your fingers
  3. Slide each new cartridge forward into the empty slot. Then gently push the upper part of the cartridge forward until it clicks into place.
    • Insert the tri-color cartridge into the left slot.
    • Insert the black cartridge into the right slot.
    Figure : Insert the cartridge
    Insert the cartridges into the appropriate slots in the carriage
  4. Close the cartridge door.
Step eleven: Align the cartridges
The product prompts you to align cartridges every time you install a cartridge. You can also align the cartridges at any time from the control panel, or by using the software you install with the product. Aligning the cartridges ensures high quality output.
  1. Make sure you have letter or A4 unused plain white paper loaded in the input tray.
  2. Press OK. The product prints an alignment page.
  3. Place the alignment page print-side down on the scanner glass.
  4. Press OK to scan the alignment page. When the scan finishes, the alignment is complete.
If you have colored paper loaded in the input tray when you align the cartridges, the alignment will fail. Load unused plain white paper into the input tray, and then try the alignment again.
