HP Designjet 1000 Series 1050c, 1050c Plus, 1055CM, 1055CM Plus Printers - Overview and Specifications
Product description
The HP Designjet 1000 series printing system is a complete large-format productivity solution for CAD and GIS departments. These printers deliver outstanding line and image quality at fast speeds with minimal user intervention.
Product features
  • Three times faster print speed (over the HP Designjet 750C+ printer).
  • Three times "click-to-clunk" overall throughput improvement (over the HP Designjet 750C+ printer).
  • True 600-dpi output for crisper text, finer lines, and improved image resolution.
  • Addressable 1200-dpi mono resolution.
  • Network-ready.
  • 1 GB hard disk drive.
  • Increased ink unattendedness with 350 cc/175 cc (CMY) and 350 cc (K) off-axis ink cartridges.
  • Long-life printheads.
  • Increased paper unattendedness with 300 ft HP bright white paper jumbo rolls.
  • Improved ink-level sensing (low-ink and overnight printing indicator).
  • Ability to load cut-sheet without manually unloading roll paper.
  • Support for thin paper (Asian tracing paper).
  • Glossy paper support.
  • HP-GL, HP-GL/2, and HP RTL languages supported.
  • VarWare support.
  • New Front panel for improved ease of use.
Software overview
Feature
HP Designjet 1055CM
HP Designjet 1050c
Microsoft Windows; AutoCAD 2000-2004, Release 13, 14 drivers for Windows; TIFF and JPEG files accepted from UNIX, Linux and Windows NT 4.0 via ZEHRaster Plus and Adobe PostScript 3T drivers for Windows 95, NT 4.0, 98, 2000, Me, XP Home, XP Professional, Server 2003, Mac OS 8.1 and higher, Mac OS X v 10.1.x, 10.2.x, 10.3.x
Microsoft Windows; AutoCAD 2000-2004, Release 13, 14 drivers for Windows; TIFF and JPEG files accepted from UNIX, Linux and Windows NT 4.0 via ZEHRaster Plus software
Operating systems compatibility
Windows 2000; Windows XP Home; Windows XP Professional; Windows Server 2003; Linux; UNIX; Mac OS 8.1 to 9.1; Mac OS X
Print drivers, standard
Microsoft Windows (2000, Server 2003, Me), AutoCAD 13,14 AutoCAD 2000-2004 (Microsoft Windows), TIFF and JPEG files accepted from UNIX, Linux, and Microsoft Windows NT 4.0 via ZEHRaster Plus software, Adobe PostScript drivers for Windows (95, 98, Me, NT 4.0, 2000, Server 2003, XP), Mac OS 8.1 and higher and Mac OS X v 10.1.x, 10.2.x, 10.3.x
Microsoft Windows (XP, 2000, Server 2003, Me), AutoCAD 13,14 AutoCAD 2000-2004 (Microsoft Windows), TIFF and JPEG files accepted from UNIXR, Linux and Microsoft Windows via ZEHRaster Plus software
System requirements
  • Windows 9x
  • Windows 3x
  • Windows NT
  • UNIX (R)
    If you have any questions about whether an application supports this printer, first check the software documentation, and, if necessary, contact the software vendor for advice.
1050c Connectivity
  • Industry-standard HP-GL, HP-GL/2 and HP-RTL languages supported
  • Adobe (R) Postscript(R) Level III option available
  • Built-in networking option through EIO (10/100-Base-T)
  • Two EIO slots (one for hard disk, the other for networking/fast direct connect)
  • Two EDO slots for RAM DIMMs up to 128 MB
  • One parallel connector
  • AutoCAD (Windows 3x, 9x, and Windows NT drivers shipped in the box)
1055CM Connectivity
  • Industry-standard HP-GL, HP-GL/2, and HP-RTL languages supported
  • Built-in Adobe PostScript Level III
  • Network ready (100Base-T)
  • HP Jetdirect print server (a network interface card) for LAN connections
  • 2 EDO Slots for RAM DIMMS up to 128 MB
  • 1 Parallel connector; 1 Serial connector
Media specifications
Roll paper
Characteristic
Specification
Paper length:
All film types
Heavyweight coated paper
91.4 m (300 feet)
38 m (125 feet)
30.5 m (100 feet)
Maximum outside diameter of roll
99 mm (3.9 inches) across any diameter
Inside core diameter
50.8 mm (2 inches)
Roll widths
610 mm (24 inches) and
914 mm (36 inches)
Side margins (normal)
5 mm (0.20 inches)
Side margins (extended)
15 mm (0.59 inches)
Leading edge
12 mm (0.47 inches)
Trailing edge
5 mm (0.20 inches)
Sheet paper
The printer series accommodates all standard and odd paper sizes. The width ranges from 210 mm to 917 mm (8.3 to 36.1 inches). The maximum sheet length is 1600 mm (63 inches).
Media types
  • HP bright white Inkjet paper
  • HP translucent bond
  • HP Vellum
  • HP natural tracing paper
  • HP clear film
  • HP matte film
  • HP heavyweight coated paper
    See also the Supplies Source catalog and (in Europe and USA) the HP Paper Guide for HP Designjet printers.
    New paper types may become available. For up-to-date information, contact the HP dealer or the local HP sales and support office.
Margins roll/sheet
Specification
Side margins
Leading edge margin
Trailing edge margin
Roll
(normal)
5 mm
(0.20 inches)
12 mm
(0.47 inches)
5 mm
(0.20 inches)
Sheet
(normal)
5 mm
(0.20 inches)
12 mm
(0.47 inches)
15 mm
(0.59 inches)
Roll
(extended)
15 mm
(0.59 inches)
12 mm
(0.47 inches)
5 mm
(0.20 inches)
Sheet
(extended)
15 mm
(0.59 inches)
12 mm
(0.47 inches)
15 mm
(0.59 inches)
Ink
The ink system includes three components: a printhead, printhead cleaner, and an ink cartridge to provide large-capacity ink, unattended printing, ease of use, reliability, and low cost. The ink system offers true 600 dpi and advanced dithering algorithms for exceptional image quality prints.
Each 600 dpi thermal Inkjet printhead applies ink droplets onto paper and has a reservoir that holds enough ink for several prints. The printer automatically refills the printhead from the ink cartridge whenever the ink volume in the printhead reservoir becomes low. The printer uses the printhead cleaners to clean and maintain the printheads, to ensure best possible image quality, and to seal the printheads when they are not in use to ensure long life.
HP80 Ink supplies
The ink system components (the printhead, printhead cleaner, and ink cartridge) are called the HP80 Ink Supplies, and they are coded with an HP80 icon to help to reorder the correct replacement components.
Each color ink cartridge (cyan, magenta, yellow, and black) can be purchased separately from an HP retailer and should be purchased when an existing ink cartridge is low on ink, if you intend to print continuously.
The printhead and printhead cleaner are supplied as a single unit and should always be installed as a matched pair. They do not require replacement every time a new ink cartridge is installed in the printer. It is only necessary to replace the printhead/printhead cleaner when the existing components are time expired.
Memory
The DesignJet 1050c and 1055CM come with 32 MB of memory expandable to a maximum of 128 MB.
The DesignJet 1050c PLUS and 1055CM PLUS come with 64 MB of memory expandable to a maximum of 256 MB.
Performance/print quality
Print quality
Print resolution
Fast
300 x 300 dpi
Normal
600 x 600 dpi
Best
Color prints:
600 x 600 dpi
Grayscale prints:
1200 x 600 dpi
Print speed
Quality
Size
Mono speed
Color speed
Normal
2 x 3 ft
(609 x 914 mm)
1:20
2:00
Best
2 x 3 ft
(609 x 914 mm)
2:15
4:00
Accuracy
0.38 mm (0.015 inches) or 0.2 percent of the specified vector length, whichever is greater, at 23 degrees C (73 degrees F), 50 to 60 percent relative humidity on HP special polyester film.
Programming languages supported
  • CALS
  • HP-GL
  • HP-GL/2 (with Kanji Level 1 and 2 character sets)
  • HP-RTL (with color extensions)
  • PJL, PML
  • Adobe PostScript Level 3 (supports Asian languages)
  • VarWare
Reliability
Feature
Reliability
35 percent Annualized Failure Rate (AFR)
Duty cycle
14.77 square meters (159 sq. feet) per day
Physical specifications
Feature
Without stand:
59 kg (130 pounds)
With stand:
81 kg (178 pounds)
Length
1566 mm (61.7 inches)
Depth
675 mm (26.6 inches)
Height
1290 mm (50.8 inches)
Electrical specifications
Feature
Source
100 to 240 volts AC +/- 10 percent auto ranging
Frequency
50 to 60 Hz
Current
Three amp maximum
Consumption
200 watts maximum
Energy Star Rating (USA)
Maximum power in ideal state: 45 watts
Environmental specifications
If the printer temperature falls below the minimum specified operating temperature the printer may stop to protect the ink systems.
At 3000 meters altitude, the printer may have operational problems.
Condition
Operating Range
Printing:
15 to 35 degrees C (59 to 95 degrees F)
at 20 to 80% relative humidity
Optimal print quality:
22 to 26 degrees C (72 to 79 degrees F)
at 30 to 60% relative humidity
Acceptable print quality:
15 to 30 degrees C (59 to 86 degrees F) at 20-80% relative humidity
Storage
Printer:
-40 to 70 degrees C (-40 to 158 degrees F)
Packed system:
-40 to 60 degrees C (-40 to 140 degrees F)
Acoustic specifications
Feature
Specification
Operating sound pressure
54 dB (From a one-meter, bystander position)
Idle sound pressure
Less than 30 dB (A) (From a one-meter, bystander position)
Operating sound power
6.5 Bels (A)
Idle sound power
Less than 4.3 Bels (A)
General warranty statement
HP Product
Duration of Warranty
Printer and related HP hardware
One year
Printheads
700cc of ink consumption or until end of exp date (whichever is first)
Ink cartridges
Until original ink is consumed or until end of exp date (whichever is first)
90 days
Safety certifications
Electromagnetic Compatibility (EMC) Specifications
Canada
Canadian Department of Communications, Radio Interference Regulations Class B (1) compliant
European Union
89/336/EEC EMC Directive compliant
Meets EN 55022 Class B(1) emission limits, prEN 55024-2 ESD, prEN55024-3 Radiated Immunity, prEN 55024-4 Fast Transients.
Japan
Registered VCCI Class B(1)
Korea
RRL certified
South Africa
SABS licensed
USA
Federal Communications Commission
Class B(1) computing device
CFR 47 Part 15
Australia
New Zealand
Meets AS/NZS 3548
Taiwan
BCIQ certified
[1] Product exhibits Class A operation when connected to LAN cables using Print Server accessories.
Printer Safety Specification
Information Technology Equipment (ITE),
Movable,
Class I,
Pluggable Type A,
Installation Category II,
Pollution Degree 2.
For use in indoor, controlled office environments
Canada
Canadian Standards Association "Certified" ITE, CSA C22.2 No.950
European Union
73/23/EEC Low Voltage Directive compliant. Meets EN 60950
Mexico
DGN, NOM019-SCFI-1994 certified
Norway
NEMKO approved,
EN 60950, EMKO TSE (74) DK207/94
USA
Underwriters’ Laboratories
"Listed" ITE, UL 1950
China
CCIB certified GB 4943-90 1st Ed.
Czech Republic
EZU, IEC950 certified
Singapore
PSB, SS337 certified
Poland
PCBC certified
Russia
GOST certified
Regulatory notices
To obtain a Material Safety Data Sheet (MSDS)
You can obtain current Material Safety Data Sheets for the ink systems used in the printer via the HP Web site (www.hp.com).
The US Federal Communications Commission (in 47 cfr 15.105) has specified that the following notice be brought to the attention of those using this product.
This device complies with part 15 of the FCC rules. Operation is subject to the following two conditions:
  1. This device may not cause harmful interference.
  2. This device must accept any interference received, including interference that may cause undesired operation.
Pursuant to Part 15.21 of the FCC Rules, any changes or modifications to this equipment not expressly approved by the Hewlett-Packard Company, may cause harmful interference and void the FCC authorization to operate this equipment.
This equipment has been tested and found to comply with the limits for a Class B digital device, pursuant to part 15 of the FCC Rules. These limits are designed to provide reasonable protection against harmful interference in a residential installation. This equipment generates, uses and can radiate radio frequency energy and, if not installed and used in accordance with the instructions, may cause harmful interference to radio communications. However, there is no guarantee that interference will not occur in a particular installation. If this equipment does cause harmful interference to radio or television reception, which can be determined by turning the equipment off and on, you are encouraged to try to correct the interferences by one or more of the following measures:
  • Reorient the receiving antenna.
  • Increase the separation between the equipment and the receiver.
  • Connect the equipment into an outlet on a circuit different from that to which the receiver is connected.
  • Consult the dealer or an experienced radio/TV technician for help.
You may find useful the following booklet prepared by the FCC: "How to Identify and Resolve Radio-TV Interference Problems." This booklet is available from the US Government Printing Office, Washington, DC 20402, and Stock No. 004-000-00345-4.
Shielded cables
Use of shielded data cables is required to comply with the Class B limits of Part 15 of the FCC Rules.
When connected to LAN cables using print server accessories
This equipment has been tested and found to comply with the limits for a Class A digital device, pursuant to part 15 of the FCC Rules. These limits are designed to provide reasonable protection against harmful interference in a commercial environment. This equipment generates, uses and can radiate radio frequency energy and, if not installed and used in accordance with the instructions, may cause harmful interference to radio communications. Operation of this equipment in a residential area is likely to cause harmful interference in which case the user will be required to correct the interference at their own expense.
DOC statement (Canada)
This digital apparatus does not exceed the Class B limits for radio noise emissions from digital apparatus set out in the Radio Interference Regulations of the Canadian Department of Communications.
When connected to LAN cables using print server accessories, this digital apparatus does not exceed the Class A limits for radio noise emissions from digital apparatus set out in the Radio Interference Regulations of the Canadian Department of Communications.
Telecommunications statement
The HP Designjet 1050C and 1055CM printers, models C6074 and C6075, are approved under Approval Number NS/G/1234/5/100003 for indirect connection to public telecommunication systems within the United Kingdom.
