HP Compaq 8710w Mobile Workstation Product Specifications
Product description
The HP Compaq 8710w Mobile Workstation redefines power on the move by combining the visualization power of NVIDIA’s next-generation graphics controller with the computational power of Intel Core2 Duo Processors into a sleek 17-inch diagonal wide-screen mobile workstation.
Product features
Feature
Specification
Processor
  • Intel Core2 Duo (up to 2.4-GHz, 4-MB L2 cache)
  • Intel Core2 Duo (1.8-GHz, 2-MB L2 cache)
Mobile Intel PM965
Memory
DDR2 SDRAM, 667-MHz, two slots supporting dual channel memory, 512/1024/2048-MB SODIMMs, up to 4096-MB total.
Hard drive(s)
  • SATA 80/120/160-GB 5400 rpm
  • SATA 80/100-GB 7200 rpm
  • HP 3D DriveGuard
Removable media
12.7-mm optical drives:
  • Blu-ray Disc DVD+/-RW SuperMulti DL
  • DVD+/–RW SuperMulti DL LightScribe
  • DVD/CD-RW Combo
  • DVD-ROM
  • 17.0-inch diagonal WXGA+
    (1440 x 900 and 16M colors)
  • 17.0-inch diagonal WSXGA+ WVA
    (1680 x 1050 and 16M colors)
  • 17.0-inch diagonal WSXGA+ WVA BrightView
  • 17.0-inch diagonal WUXGA WVA
    (1920 x 1200 and 16M colors)
Graphics
NVIDIA Quadro FX 1600M with 512 MB of video memory
Audio
  • High Definition Audio
  • Stereo speakers
  • Stereo headphone/line out
  • Stereo microphone in
  • Integrated microphone
Wireless support
  • Intel 802.11a/b/g/draft-n, a/b/g, b/g
  • Broadcom 802.11a/b/g draft-n, a/b/g, b/g
  • Bluetooth 2.0
  • HP Wireless Assistant
Communications
Intel Gigabit Network Connection (10/100/1000 NIC), 10 56K v.92 modem
1 Type I/II PC Card slot supports 32-bit CardBus and 16-bit cards, Media Card Reader
Ports and connectors
  • 6 USB 2.0 ports
  • VGA
  • HDMI
  • 1394a
  • Power connector
  • RJ-11/modem
  • RJ-45/ethernet
  • Docking connector
  • Secondary battery connector
Input device
  • Full-sized keyboard
  • Enhanced dual pointing devices (touchpad with scroll zone and pointstick)
Manageability
  • Intel Centrino Pro processor technology capable
  • HP Backup and Recovery Manager
  • HP Client Manager Software
  • HP OpenView Radia Management Agent
  • HP Client Management Interface
  • HP Performance Tuning Framework
Security
  • HP ProtectTools
  • TPM Embedded Security Chip 1.2, HP Fingerprint Sensor
  • Symantec Norton Internet Security
  • Integrated Smart Card Reader (Sold separately)
  • Kensington lock
  • HP Privacy Filter
Dimensions
(h × w × d)
1.3 in (at front) x 15.5 in x 10.8 in/33 mm (at front) x 393 mm x 275 mm
Starting at weight: 7.5 lbs/3.40 kg (weight will vary by configuration)
Power
  • 8-cell (73 WHr) Lithium-Ion battery
  • Optional HP (52 WHr) Extended Life Battery
  • Optional HP (95 WHr) Ultra-Capacity Battery
  • 120W HP Smart AC Adapter
  • HP Fast Charge
Expansion solutions
  • HP 3-in-1 NAS Docking Station
  • HP Advanced Docking Station
  • HP Docking Station, External MultiBay II
  • HP Monitor Stand
  • HP Adjustable Notebook Stand
Limited 3-year,1-year, and 90-day limited warranty options available depending on country; 1-year limited warranty on primary battery
Software/OS
Feature
Specification
Preinstalled:
  • Genuine Windows Vista Business 32/64
  • Genuine Windows Vista Home Basic
  • Genuine Windows XP Professional
  • FreeDOS
Supported:
  • Genuine Windows Vista Enterprise
  • Genuine Windows 2000
Certified:
  • SuSe Linux Enterprise Desktop 10
Warranty information
Terms of warranty apply to the individual model purchased. To see if your HP product is still in warranty, go to the HP Product Warranty Check page.
