HP LT4200 42 inch Professional LCD HDTV - Overview
Product Description
The HP LT 4200 42-inch Professional LCD HDTV offers beautiful 1080p resolution, exceptional image accuracy, clear pictures, and rich connectivity for professional environments.
Product Features
Product specifications
Display type
Active matrix TFT
Viewable area
42.2 in(107.2 cm)
Native resolution
1920 x 1080
Signal input
480i, 480p, 720p, 1080i, 1080p (HDMI Only), 640 x 480, 800 x 600, 1024 x 768, 1280 x 768, 1280 x 1024, 1360 x 768
Viewing angle (horizontal)
176 degrees
Response rate (typical)
8 ms
Audio
Dual speakers, 20 watts (total), Dolby digital output, virtual surround (theater, music hall), SAP/MTS
Ports
Rear:
2 component in
4 analog audio in
2 composite/s-video in
1 digital audio out (optical)
1 RGB-VGA PC input
1 PC audio input
1 analog audio out (stereo)
1 antenna in (RF)
1 RS-232
Cabinet Colors
Black, semi-gloss finish
Image quality
Brightness (typical)
500 cd/m²
Contrast ratio (typical)
1200:1
Preset resolutions - refresh rates
640 x 480 @ 60 Hz
720 x 400 @ 70 Hz
1360 x 768 @ 85.5 MHz
1920 x 1080 @ 74.25 MHz
Resolution max
1920 x 1080
Ease of use features
On-Screen controls
Yes (OSD lockout
keypad lockout)
Interface and performance features
FullHD 1080p Resolution
Integrated NTSC/ATSC/clear QAM Tuner
Advanced RS-232 Controls
User programmable picture and audio settings
Compliance
Approvals and Certifications
BETS-7; C-UL; Energy Star Qualified TV; FCC Approval; UL Listed
Hardware features
Dimensions (w x d x h)
29.0 x 11.0 x 40.0 in (73.66 x 27.94 x 101.6 cm)
61.6 lb (27.94 kg)
Service and Support
Warranty - year(s)
2-years part, labor, on-site (2/2/2). Extended, optional three-year warranty available.
