    Fix HP Printer issue on macOS
HP iPAQ 500 Voice Messenger Series - Checking the Battery Charge Level
To check the battery power:
  • Press Start > Settings > More... > Power Management.
If the battery charge level is low, recharge the battery by connecting the iPAQ to an AC power supply using the desktop cradle or the AC Adapter, or change the battery.
For information on purchasing an optional standard battery, visit the HP Web site at www.hp.com/go/ipaqaccessories.
Do not allow the battery installed in your iPAQ to discharge completely. Doing so will not harm your Pocket PC or battery, but your Pocket PC will lose all data not stored in ROM.
