    Fix HP Printer issue on macOS
HP iPAQ 500 Voice Messenger series- Using the Digital Camera
Use the built-in digital camera on your iPAQ to click photos and record videos.
To Capture Photos
You can capture images and store them in your iPAQ or memory card.
  1. Press Start > More > Camera.
To View Photos
You can view photos captured on your iPAQ:
  1. Press Start > More > Pictures & Videos.
  2. Navigate to a required folder or image.
  3. Press View to view a photo and press Open to open a folder.
  4. Navigate the folder to select a required image, and then press View.
To Change Image Sizes
  • Press the Action button once to display photo in full screen view.
    The opened photo displays in the fit to view screen by default.
  • Press the Action button once while in full screen view to display photo in actual view.
  • Press the Action button once while in actual view to return back to fit to screen view.
    You can create folders to manage your pictures. Press Menu > Edit > New Folder to create a new folder.
Using the Camcorder
Recording Videos
You can use the built-in camcorder in your iPAQ to create short videos and share them with your friends and family.
  2. Press Menu > Video.
  3. Press the Action button to start recording. Press the Action button again to Stop recording.
Configuring Video Format
  1. Tap Start > Programs > Pictures & Videos , and then tap Menu > Options > Video.
    • Select the Include audio when recording video files. check box to record both audio and video.
    • Set time limit to one of the following:
      • 30 Seconds
      • 15 Seconds
      • No Limit
By default, all the pictures and videos are stored in \My Documents\My Pictures.
