HP Photosmart D7200, D7300, and D7400 Series Printers - Loading and Printing on 101.6 x 152.4 mm (4 x 6 inch) Photo Paper from the Photo Tray in Windows
This document describes how to load and print on 101.6 x 152.4 mm (4 x 6 inch) photo paper from the photo tray of the printer.
Loading and printing on 101.6 x 152.4 mm (4 x 6 inch) paper from the photo tray
Follow these steps to load photo paper, and then print from the photo tray
Step one: Load the 101.6 x 152.4 mm (4 x 6 inch) photo paper
  1. Raise the output tray, and then pull out the photo tray.
    Figure : Raise the output tray and pull out the photo tray
    Illustration: Raising the output tray and pulling out the photo tray
  2. Insert the stack of photo paper into the photo tray with the short edge forward and the print side down. Slide the stack of photo paper forward until it stops.
    If the photo paper has perforated tabs, load the photo paper so that the tabs face away from the product.
  3. Slide the paper length and paper width guides inward until they rest against the stack of photo paper.
    Do not overload the photo tray. Make sure that the stack of photo paper fits within the photo tray and does not reach the top of the paper-width guide.
    Figure : Place a stack of photo paper into the photo tray
    Illustration: Placing a stack of photo paper into the photo tray
  4. Push in the photo tray, and then lower the output tray.
Step two: Change the print settings
  1. On the File menu in your software application, click Print.
  2. Click the button that opens the Properties window.
    Depending on your software application, this button might be called Properties, Options, Printer Setup, Printer, or Preferences.
  3. Click the Features tab.
  4. In the Basic Options area, select the appropriate photo paper type from the Paper Type drop-down list.
  5. In the Resizing Options area, click the appropriate paper size from the Size list. If the paper size and paper type are not compatible, the HP Photosmart software displays an alert and allows you to select a different type or size.
  6. In the Basic Options area, select a high print quality, such as Best or Maximum dpi from the Print Quality drop-down list.
  7. In the HP Real Life technologies area, click the Photo fix drop-down list and select from the following options:
    • Off: applies no HP Real Life technologies to the image.
    • Basic: automatically focuses the image; moderately adjusts image sharpness.
    • Full: automatically lightens dark images; automatically adjusts sharpness, contrast, and focus of images; automatically removes red eye.
  8. Click OK to return to the Properties window.
Step three: Print on 101.6 x 152.4 mm (4 x 6 inch) photo paper
  1. If you want to print the photo in black and white, click the Color tab, and then select the Print in grayscale check box.
  2. Click OK, and then click Print or OK in the Print window.
Country: Flag Vietnam
