HP Compaq nx6315 Business Notebook PC - Overview
Product description
Starting from 2.6kg, the HP Compaq nx6315 Notebook PC features AMD Turion 64 X2 Mobile Technology processors in a 15 inch display.
Product features
Feature
Processor and memory
Processor
  • AMD Turion 64 X2 Dual-Core Mobile Processor TL-64 (2.2-GHz, 2 x 512-KB L2 cache)
  • AMD Turion 64 X2 Dual-Core Mobile Processor TL-60 (2.0-GHz, 2 x 512-KB L2 cache)
  • AMD Turion 64 X2 Dual-Core Mobile Processor TL-56 (1.8-GHz, 2 x 512-KB L2 cache)
  • AMD Turion 64 X2 Dual-Core Mobile Processor TL-52 (1.6-GHz, 2 x 512-KB L2 cache)
  • AMD Turion 64 X2 Dual-Core Mobile Processor TL-50 (1.6-GHz, 2 x 256-KB L2 cache)
  • AMD Turion 64 Mobile Processor MK-36 (2.0-GHz, 512-KB L2 cache) Mobile
  • AMD Sempron Processor 3500+ (1.8-GHz, 512-KB L2 cache) Mobile
  • AMD Sempron Processor 3400+ (1.8-GHz, 256-KB L2 cache) Mobile
  • AMD Sempron Processor 3200+ (1.6-GHz, 512-KB L2 cache)
Processor speed denotes maximum performance mode; processors will run at lower speeds in battery optimization mode.
  • ATI Radeon Xpress 1150 Chipset
Memory
Standard
  • 256 MB 667 MHz DDR2 SDRAM
  • 512 MB 667 MHz DDR2 SDRAM
  • 1 GB 667 MHz DDR2 SDRAM
  • 2 GB 667 MHz DDR2 SDRAM
Maximum
  • Upgradeable to 4096-MB maximum (2048-MB SODIMM in slots 1 and 2).
Dual-channel
  • Maximized dual-channel performance requires SODIMMs of the same size and speed in both memory slots.
Due to the non-industry standard nature of some third-party memory modules, we recommend HP branded memory to ensure compatibility. If you mix memory speeds, the system will perform at the lower memory speed. Above 3-GB, all memory may not be available due to system resource requirements.
Storage
Hard drives
  • 40 GB 5400 rpm SATA
  • 60 GB 5400 rpm SATA
  • 80 GB 5400 rpm SATA
  • 100 GB 5400 rpm SATA
These hard drives are customer removable and will withstand multiple insertion/removal cycles. Up to 8 GB is reserved for the system recovery software.
HP Mobile Data Protection System 3D
  • Hard drive is mounted directly to the notebook frame, reducing the transmission of shock to the hard drive. Uses three-axis digital motion detection with intelligent sensitivity to help protect the hard drive during normal use from shock and vibration.
Fixed Optical Drives
  • CD-ROM
  • DVD/CD-RW Combo
  • DVD+/-RW SuperMulti with Double Layer
  • LightScribe DVD+/-RW with Double Layer
Connectivity
Wireless devices
Support for a broad range of secure, integrated wireless LAN options featuring support for the latest industry standards. Integrated Bluetooth is also an option (factory configurable only) and can be combined with any one of the supported wireless LAN options.
  • All integrated wireless LAN options
    • Wi-Fi certified
    • Cisco Compatible Extensions support (Version 3.0)
    • Wired Equivalent Privacy (WEP) support up to 128-bit keys
    • Wi-Fi Protected Access (WPA) and WPA2 support
    • 802.1x authentication support, including EAP-TLS, EAP-TTLS, PEAP-GTC, PEAP-MSCHAPv2, and LEAP
    • Advanced Encryption Standard (AES) support
    • WiFi Certified for WPA2, WMM
    • Dual antennas integrated in the display enclosure
  • Broadcom 4311AG WiFi Adapter
    • Integrated support for 802.11b and g
    • Up to 54-mbps data rate
  • Broadcom 4311BG WiFi Adapter
  • HP Integrated Module with Bluetooth 2.0 Wireless Technology
    • Bluetooth Specification v2.0 compliant
    • Works with a wide range of Bluetooth devices
Communications
  • Broadcom (10/100 NIC) Ethernet PCI Controller
  • 56K V.92 modem with digital line guard
    Designed for downloads from 56K modem compliant sources. Maximum achievable download transmission rates currently do not reach 56 KB/s, and will vary with line conditions. Modem availability is subject to country regulatory approval.
Expandability
  • One Type I/II PC Card slot
    • Supports 32-bit CardBus and 16-bit PC Cards
Graphic / audio
Graphics
  • ATI Radeon Xpress 1150, up to 128-MB shared system memory
    • Microsoft DirectX 9 capable
Audio
  • PremierSound audio/speaker subsystem
  • ADI1981HD High Definition CODEC
  • Integrated 16-bit Sound Blaster Pro compatible audio
  • 24-bit DAC
  • Integrated stereo speakers
  • Stereo headphone/line out
  • Stereo microphone in
Power and Battery
Battery
  • Primary Battery
    • 55Wh 6-cell high capacity Lithium-Ion
    • 43Wh 6-cell high capacity Lithium-Ion
  • Optional 8-Cell Extended Life Battery
    • 52Wh 8-cell high capacity Lithium-Ion
  • Optional HP 12-Cell Ultra-Capacity Battery
    • 95Wh 12-cell high capacity Lithium-Ion
Power supply
  • External 65-watt Smart AC adapter, 6-foot (1.8-meter) power cord included.
  • Total length including External AC adapter is 12 feet (3.66 meter)
  • HP Fast Charge Technology
    Fast Charge Technology recharges your battery up to 90% within 90 minutes when the system is off. Fast Charge Technology does not apply to 12-cell Ultra-Capacity batteries.
Other information
Keyboard
  • The 101/102-key compatible keyboard features an industry standard, full-pitch key layout with desktop keyboard features, such as the isolated inverted-T cursor control keys, editing keys, both left and right control and alt keys, and 12 function keys. US and International key layouts are available. Other features include an integrated numeric keypad, hotkeys for instant access to power conservation, brightness, and other features, 19-mm x 19-mm key pitch (center-to-center spacing), 2.5-mm stroke, comfort-dished keycaps, and bright key legends for improved visibility in low light conditions.
Pointing device
  • Touchpad with scroll zone, two soft-touch buttons
One-Touch Productivity Buttons
  • Provides one-touch access to control Wireless On/Off, with LED indicator
Connectors
  • PC Card Slot - One (Type I/II)
  • External Monitor - One (VGA)
  • IEEE 1394a Port - One
  • External Microphone - One
  • Headphone/Line out - One
  • Power Connector - One
  • RJ-11 (Modem) - One
  • RJ-45 (NIC) - One
  • USB 2.0 - Two
  • Accessory Battery Connector - One
  • LED Status Indicators - Ten
Software overview
Feature
Specification
Preinstalled:
  • Genuine Windows Vista Business 32/64
  • Genuine Windows Vista Home Basic 32
  • Genuine Windows XP Professional
  • Genuine Windows XP Home Edition SP2
  • FreeDOS
Supported:
  • Genuine Windows Vista Business 64
  • Genuine Windows Vista Enterprise 32/64
  • Genuine Windows XP Professional x64 Edition
  • Genuine Windows 2000
Certified:
  • SuSe Linux Enterprise Desktop 10
Preinstalled Software with Windows Vista or Windows XP:
  • Adobe Acrobat Reader
  • HP Backup and Recovery Manager
  • HP Help and Support Center*
  • HP Mobile Print Driver (Windows XP models)
  • HP ProtectTools Security Manager:
    • BIOS Configuration for HP ProtectTools
    • Credential Manager for HP ProtectTools
  • HP Quick Launch Buttons
  • HP Wireless Assistant
  • Sonic Digital Media Plus (Windows XP models):
    • RecordNow! (for optional DVD+/-RW and DVD/CDRW drives)
    • MyDVD (DVD Authoring for optional DVD+/-RW drives)
  • Roxio Creator 9 (Window Vista models with optional DVD+/-RW or DVD/CDRW drives)
  • Synaptics Touchpad Driver
  • Symantec Norton Internet Security with complimentary 60-day live update
  • Intervideo WinDVD - DVD Player (for optional DVD+/-RW, DVD/CDRW and DVD drives)
Additional software available from the web:
  • SmartCard Security for HP ProtectTools
  • Device Access Manager for HP ProtectTools
Warranty information
HP Services includes a one-year standard parts and labor warranty, pick-up or carry-in, and toll-free 7 x 24 hardware technical phone support. On-site service and warranty upgrades are also available.
Links to QuickSpecs
Information for this Overview is taken from the product QuickSpecs. To access the complete QuickSpecs for this product, select the desired link from the following list:
This product only has Worldwide QuickSpecs.
