    We are upgrading our website
HP Compaq nw8440 Mobile Workstation - Overview
Product Description
Power-packed with high-end graphics and uncompromising system performance in a thin and light design, the HP Compaq nw8440 Mobile Workstation allows you to easily work beyond the office without compromising performance demands.
Product Feature
Feature
System features
Genuine Windows XP Professional SP2
Genuine Windows XP Home SP2
FreeDOS
Processor type
Intel Core 2 Duo
Intel Core Duo
Processors available
Intel Core 2 Duo Processor T7600 2.33 GHz 4 MB L2 cache 667 MHz front side bus
Intel Core 2 Duo Processor T7400 2.16 GHz 4 MB L2 cache 667 MHz front side bus
Intel Core 2 Duo Processor T7200 2.0 GHz 4 MB L2 cache 667 MHz front side bus
Intel Core 2 Duo Processor T5600 1.83 GHz 2 MB L2 cache 667 MHz front side bus
Intel Core Duo processor T2600 2.16 GHz 2 MB L2 cache 667 MHz front side bus
Intel Core Duo processor T2500 2.0 GHz 2 MB L2 cache 667 MHz front side bus
Intel Core Duo processor T2400 1.83 GHz 2 MB L2 cache 667 MHz front side bus
Processor cache
4 MB L2 cache
2 MB L2 cache
Mobile Intel 945PM Express
Memory
Memory
512 MB 533 MHz DDR2 SDRAM
1 GB 533 MHz DDR2 SDRAM
2 GB 533 MHz DDR2 SDRAM
512 MB 667 MHz DDR2 SDRAM
1 GB 667 MHz DDR2 SDRAM
2 GB 667 MHz DDR2 SDRAM
Memory slots
2 SODIMM slots
Memory upgrade
Upgradeable to 4 GB maximum (2 GB SODIMM in slots 1 and 2)
Storage
Hard drives
60 GB 5400 rpm SATA
80 GB 5400 rpm SATA
100 GB 5400 rpm SATA
120 GB 5400 rpm SATA
80 GB 7200 rpm SATA
100 GB 7200 rpm SATA
Audio, Slots, and Ports
Audio
ADI High Definition CODEC; Integrated 16-bit Sound Blaster Pro compatible audio; Integrated stereo speakers; Integrated directional microphone; External volume up and down, and mute buttons; Stereo headphone/line out; Stereo microphone in
Ports
Standard:
3 USB 2.0
1 IEEE 1394(a)
1 RJ-45
1 RJ-11
1 microphone in
1 headphone/line-out
1 S-video
1 serial
1 AC power
1 docking connector
Rear:
1 external VGA monitor
1 battery connector
Slots
1 Type I/II PC Card slot
1 Smart Card Reader
1 secure digital
Graphics and Input/Output devices
Display size
15.4-inch WSXGA+;15.4-inch WUXGA
Graphics cards
ATI Mobility FireGL V5200 graphics controller with 256 MB of video memory
Microsoft DirectX 9 capable
Input devices
Dual pointing devices – Touchpad with scroll zone and three soft-touch buttons and Pointstick with three soft-touch buttons
Keyboard
The 101/102-key compatible keyboard features an industry standard, full-pitch key layout with desktop keyboard features, such as the isolated inverted-T cursor control keys, editing keys, both left and right control and alt keys, and 12 function keys. US and International key layouts are available.; Other features include an integrated numeric keypad, hotkeys for instant access to power conservation, brightness, and other features, 19-mm x 19-mm key pitch (center-to-center spacing), 2.5-mm stroke, comfort-dished keycaps, and bright key legends for improved visibility in low light conditions.
Docking Solutions
HP Docking Station; HP Advanced Docking Station
Communication features
Network
Integrated Broadcom NetXtreme Gigabit Ethernet PCIe Controller (10/100/1000 NIC) with HP Smart Power NIC Technology
Modem
56K V.92 modem with digital line guard
Wireless
Integrated Intel PRO/Wireless 3945ABG Network Connection; Integrated Broadcom 4311AG WiFi Adapter; Integrated Broadcom 4311BG WiFi Adapter; HP Integrated Module with Bluetooth 2.0 Wireless Technology
Manageability
Security management
HP Compaq nw8440 Mobile Workstation / HP Compaq nw8440 Mobile Workstation / HP Compaq nw8440 Mobile Workstation / HP Compaq nw8440 Mobile Workstation / HP Compaq nw8440 Mobile Workstation: HP ProtectTools Security Manager; Configuration Control Hardware; Memory Change Alert; Ownership Tag; Setup Password; Power-On Password; DriveLock; TPM Enhanced DriveLock; HP Disk Sanitizer; Integrated Smart Card Reader; TPM Embedded Security Chip; Kensington lock slot
Product specifications
Dimensions (w x d x h)
14.1 x 10.2 x 1.1 in (358 x 259 x 28 mm)
5.9 lb (2.7 kg)
Power and Battery
Battery
8-cell (69WH) high capacity Lithium-Ion battery
Power supply
External 90-watt AC adapter, 6-foot (1.8-meter) power cord included. Total length including External AC adapter is 12 feet (3.66 meter). HP Fast Charge Technology
Country: Flag Vietnam
