HP Designjet T1100 Printer Series - Cannot Insert a Printhead
  1. Check that you have the correct type of printhead (model number).
  2. Check that you have removed the two orange protective caps from the printhead.
  3. Check that the colored label on the printhead is the same color as the label on the slot.
  4. Check that the printhead is correctly oriented (compare with the others).
    Figure : Pushing in the printhead
  5. Check that you have correctly closed and latched the printhead cover.
Country: Flag Vietnam
