HP Designjet 8000, 9000 and 10000 Series - Using the Shift Key to View Error Information on the Printer
The Shift key of the printer front panel has a helpful function that is not described in the User Guide.
Details
With the printer ONLINE, press the Shift key once and then read the self-scrolling information report to discover:
  • Media usage
  • Ink levels
  • User-correctable error messages (such as PERFORM DAILY MAINTENANCE NOW or REPLACE WIPE SPONGE or REPLACE WIPE LIQUID, etc.)
This is how to find out why the error LED is blinking
Use the printer's menu options to correct the error messages and the error LED will cease blinking.
