    Looking for Site Help?
Compaq Presario w17q Monitor - Product Specifications
This document applies to the Compaq Presario w17q monitor.
The Compaq Presario w17q is a 17-inch wide-screen monitor with liquid crystal display (LCD) and thin-film transistor (TFT) screen.
Figure : Compaq Presario w17q LCD wide-screen monitor
GA028AA
Features
The Compaq Presario w17q LCD wide-screen monitor has the following features:
  • 1440 x 900 factory-set resolution
  • Supports VGA analog signal video input
  • Plug and play capability, if supported by your computer system
  • On-screen display (OSD) adjustments for ease of setup and screen optimization
  • Energy Star compliant
Technical specifications
LCD feature
Specification
Display size
17-inch (43.2 cm) diagonal and viewable image
Display type
Thin-Film Transistor Active Matrix Color LCD
Anti-glare coating
Input terminal
VGA 15-pin D-type connector
Scanning frequency
Horizontal scan range 30-83 KHz
Vertical scan range 56-76 Hz
Native resolution (H x V)
1440 x 900
Contrast ratio
up to 500:1
Response time
8 ms
Pixel pitch
0.255 mm
Power source - AC/DC adapter
Input rating: 100 to 240V~
Power consumption: <37 W in operating mode, <2 W in sleep mode
Operating environment
Temperature: 41 degrees F to 95 degrees F (5 degrees C to 35 degrees C)
Humidity: 15% RH through 90% RH (non-condensing)
Storage environment
Temperature: -4 degrees F to 140 degrees F (-20 degrees C to 60 degrees C)
Humidity: 5% RH through 90% RH (non-condensing)
Dimensions
H x W x D, including base:
15.8 x 13.1 x 8.3 inches (40.1 x 33.2 x 21 cm)
Unpacked: 7.17 lbs (3.25 Kg)
EMI standard
FCC Class B
Mounting
Standard VESA 4-hole 100 mm x 100 mm
EPA Energy Star
As an Energy Star Partner, Hewlett-Packard has determined that this product meets the Energy Star guidelines for energy efficiency.
Country: Flag Vietnam
