HP CM8060/CM8050 Color MFP with Edgeline Technology - Paper attributes
Paper sources and destinations
The following table indicates the standard and optional paper sources and destinations for the HP CM8060/CM8050 Color MFP with Edgeline Technology.
HP CM8060/CM8050 Color MFP with Edgeline Technology – Paper sources and destinations
Paper sources
80-sheet manual feed tray (Tray 1)
Standard
500-sheet paper trays (Tray 2 – 4)
Standard
4000-sheet high-capacity tray (Tray 5)
Optional
Paper destinations
Single output bin
Standard
HP 4-Bin Job Separator
Optional
HP Multifunction Finisher
Optional
Paper-source commands
The PCL 6 attribute for paper source is ubyte # MediaSource or ubyte_array "string" MediaSource. See the following table for values of #. For example, "ubyte 4 MediaSource" is the command for Tray 2.
The PCL 5 escape sequence for media source is Esc&l#H (the "l" is a lowercase "L" rather than the numeral "1"). See the following table for values of #. For example, Esc&l1H is the command for Tray 2.
HP CM8060/CM8050 Color MFP with Edgeline Technology – Paper-source commands
Paper source
PCL 6
PCL 5
Esc&l#H
PostScript
/MediaPosition # /ManualFeed true | false or null
Manual feed in tray 1
2
2
3 true
Tray 1 (manual feed)
3
4
3 false
Tray 2 (500-sheet)
4
1
0 false
Tray 3 (500-sheet)
5
5
1 false
Tray 4 (500-sheet)
7
8
4 false
Tray 5 (4000-sheet high-capacity)
5
9
38 false
Automatically Select
NA
NA
NA
Printer Auto Select
1
7
null false
1For the string value, include the quotation marks around the variable. For example, ubyte_array "TRAY2" MediaSource is the PCL 6 command for Tray 2.
Driver-supported paper sizes
The following table lists the features and attributes of various paper listed under the Page size: drop-down menu on the Paper/Quality tab. The list order can vary, depending on the device and operating system. The list contains all of the following sizes, and might contain sizes from other drivers.
HP CM8060/CM8050 Color MFP with Edgeline Technology – Supported paper sizes and attributes
Paper sizes1
Width
Height
PCL 6 2
Letter
216 mm
(8.5 inches)
280 mm
(11.0 inches)
"LETTER"
Legal
216 mm
(8.5 inches)
356 mm
(14.0 inches)
"LEGAL"
Executive
184 mm
(7.25 inches)
267 mm
(10.5 inches)
"EXEC"
Statement
140 mm
(5.5 inches)
216 mm
(8.5 inches)
"STATEMENT"
8.5 x 13
216  mm
(8.5 inches)
330 mm
(13 inches)
"8.5x13"
11 x 17
280 mm
(11 inches)
432 mm
(17 inches)
“11x17”
12 x 18
305 mm
(12 inches)
457 mm
(18 inches)
“12x18”
4 x 6
102 mm
(4 inches)
152 mm
(6 inches)
“4x6”
5 x 7
127 mm
(5 inches)
178 mm
(7 inches)
“5x7”
5 x 8
127 mm
(5 inches)
203 mm
(8 inches)
“5x8”
A3
297 mm
(11.69 inches)
420 mm
(16.54 inches)
“A3”
A4
210 mm
(8.27 inches)
297 mm
(11.69 inches)
"A4"
A5
148 mm
(5.83 inches)
210 mm
(8.27 inches)
"A5"
RA3
305 mm
(12.01 inches)
430 mm
(16.93 inches)
“RA3”
RA4
215 mm
(8.46 inches)
305 mm
(12.01 inches)
“RA4”
SRA4
225 mm
(8.86 inches)
320 mm
(12.6 inches)
“SRA4”
B4 (JIS)
257 mm
(10.12 inches)
364 mm
(14.33 inches)
“JIS B4”
B5 (JIS)
182 mm
(7.17 inches)
257 mm
(10.1 inches)
"JIS B5"
B6 (JIS)
128 mm
(5.04 inches)
182 mm
(7.17 inches)
“JIS B6”
8K
273 mm
(10.75 inches)
394 mm
(15.5 inches)
“ROC8K
16K
197 mm
(7.75 inches)
273 mm
(10.75 inches)
"ROC16K"
Custom
Minimum:
102 mm
(4 inches)
Maximum:
320 mm
(12.6 inches)
Minimum:
152 mm
(6 inches)
Maximum:
457 mm
(18 inches)
3
1For all paper sizes, the PCL 6 margins are 100 dots, at 600 dots per inch.
2The PCL 6 command for paper size is ubyte_array “String” MediaSize. The values in this column are the values for "String."
3For custom sizes, the HP PCL 6 driver specifies actual dimensions, for example, for 8 x 9-inch custom size, "real32_xy 8.0 9.0 CustomMediaSize ubyte eInch CustomMediaSizeUnits."
Driver-supported paper types
When you select a paper type, you are instructing the device to use a group of predefined settings to create the best possible print quality for that type of paper.
Selecting a paper type that does not match the type of paper that is loaded in the tray can damage the device.
The following table shows the paper types that the HP CM8060/CM8050 Color MFP with Edgeline Technology print-drivers support.
HP CM8060/CM8050 Color MFP with Edgeline Technology – Supported input paper types
Paper types (command string)
Tray 1 (80-sheet manual feed)
Trays 2–4 (500-sheet)
Duplexing unit
Single output bin
Unspecified
Y
Y
Y
Y
Y
Y
Y
Plain
Y
Y
Y
Y
Y
Y
Y
HP Office LG 80g
Y
Y
Y
HP MattePrem 120g
Y
N
N
HP MatteBroch 180g
Y
N
N
HP MatteCover 200g
Y
N
N
HP GlossyEdgin 180g
Y
N
N
HP GlossyEdgin 220g
Y
N
N
Cardstock 160-220g
Y
N
N
Matte
Y
N
N
Matte Brochure
Y
N
N
Matte Cover
Y
N
N
Labels
Y
N
N
N
Y
Y
N
Letterhead
Y
Y
Y
Y
Y
Y
Y
Preprinted
Y
Y
Y
Y
Y
Y
Y
Prepunched
Y
Y
Y
Y
Y
Y
Y
Colored
Y
Y
Y
Y
Y
Y
Y
Bond
Y
Y
Y
Y
Y
Y
Y
Recycled
Y
Y
Y
Y
Y
Y
Y
Custom
Y
Y
Y
Y
Y
Y
Y
Custom paper sizes
The following table shows custom paper sizes that are available for the HP CM8060/CM8050 Color MFP with Edgeline Technology.
HP PCL 6 driver custom paper sizes
Tray
Dimensions
Minimum
Maximum
Width
76 mm (3.0 inches)
215 mm (8.5 inches)
Height
127 mm (5.0 inches)
356 mm (14.0 inches)
Trays 2 – 4 (500-sheet)
Width
148.0 mm (5.83 inches)
215 mm (8.5 inches)
Height
210 mm (8.26 inches)
Trays 5 (4000-sheet high-capacity, optional)
Width
215 mm (8.5 inches)
Height
Duplexing unit
Width
215 mm (8.5 inches)
Height
210.0 mm (8.26 inches)
The HP Stacker/Stapler/Job Separator does not support custom paper sizes.
Media-type commands
The HP PCL 5 driver escape sequence for paper type is "Esc&n#Wdpapertype", where "n#" is the number of characters in the paper type plus 1. For example, in the sequence "Esc&n6WdPlain", "Plain" has 5 letters plus 1, for a total of 6.
HP CM8060/CM8050 Color MFP with Edgeline Technology – Media-type commands
Esc&
n#
Wd
Paper type
Esc&
6
Wd
Plain
Esc&
11
Wd
Preprinted
Esc&
11
Wd
Letterhead
Esc&
11
Wd
Prepunched
Esc&
7
Wd
Labels
Esc&
5
Wd
Bond
Esc&
9
Wd
Recycled
Esc&
6
Wd
Color
Esc&
6
Wd
Light <75 g/m2
Esc&
6
Wd
Heavy
Esc&
11
Wd
Cardstock > 163 g/m2
Esc&
6
Wd
Rough
1The correct command for cardstock is "Esc&n11WdCard Stock", with a space between the "d" and the "S", and with an uppercase "S".
