HP Designjet Z3100ps Photo Printer Series - Load a single sheet
Overview
There are two ways to load a sheet. The easy loading procedure is recommended.
Any loaded roll or sheet must be unloaded before loading a sheet.
For sheets thicker than 0.5 mm, you must have space behind the printer equal to the length of the sheet.
Easy loading procedure
  1. Standing in front of the printer, open the sheet tray. If the sheet is long, extend the right extension. If the sheet is also wide extend the left extension.
    If the tray is difficult to open, try opening from behind the printer.
    Figure : Sheet trays
    The extensions are seven cm and snap in place.
  2. Insert the sheet into the feeder. Load your sheet aligned with the load line and insert until the paper can not continue, with thicker sheets you feel resistance. The printer detects the sheet in three seconds. A countdown begins on the front-panel display.
    Figure : Align sheet
      warning:
    Do not to push your fingers inside the printer's paper path.
  3. After the countdown, the paper feeds into the printer. Guide the sheet into the printer; this is especially important with thicker papers.
  4. The front-panel display asks if you are loading a roll or a sheet. Select Sheet with the Up and Down keys.
  5. Enter your paper category and type.
    Figure : Load sheet
  6. The printer checks the alignment and measures the sheet.
    Figure : Load sheet
    Depending on the length of the sheet, it feeds out the front of the printer.
  7. If the paper has been loaded successfully, the front panel displays the Ready message and the printer ready to print. If the paper is not straight, follow the instructions on the front-panel display.
When correctly loaded, the sheet is in the back of the printer.
Paper menu procedure
As an alternative you can use the paper menu to start the paper loading process
  1. Perform step one of the easy loading procedure.
  2. Press the Menu key to return to the main menu and select the (Paper menu) icon.
    Figure : Main menu
  3. Select Paper load.
    Figure : Paper load
  4. Select Load sheet.
    Figure : Paper load sheet
  5. Select your paper category and type.
    Figure : Select paper category
  6. Continue with step two of the easy loading procedure, skipping steps four and five.
