HP Designjet Z3100ps Photo Printer Series - Color Management Scenarios
The following step-by-step instructions for specific printing jobs using specific software are similar to those you can find in HP's Knowledge Center on the Web. Click here to visit http://www.hp.com/go/knowledge_center/djz3100/ to consult the Knowledge Center for further examples and for the most up-to-date information.
Print a color photo for an exhibition (Photoshop, PS driver)
This example uses Adobe Photoshop CS2 under Mac OS X, with the PostScript driver. Color management is done by Photoshop.
  1. Initial recommendations:
    • Choose an appropriate paper type for the purpose.
    • The paper type should be calibrated and profiled with the printer and the print-quality level that you intend to use.
    • For a correct preview of the printed image, the monitor should also be profiled.
  2. Open Adobe Photoshop CS2.
  3. From the Edit menu, select Color Settings.
    • Make sure that More Options are displayed.
    • Working Spaces, RGB: Select Adobe RGB (1998) or sRGB.
    • Color Management Policies: Select Preserve Embedded Profiles.
    • Profile Mismatches: Check Ask When Opening and Ask When Pasting.
    • Missing Profiles: Check Ask When Opening.
    • Conversion Options, Intent: Select Perceptual.
      Figure : Color Settings dialog box
    • Click OK.
  4. From the File menu, select Open to open the image.
    • If the document has an embedded color profile that does not match the current working space, select Use the embedded profile. Otherwise, select Assign working space; in this case, if the displayed image does not look correct, try assigning it to other color spaces with Edit, Assign Profile (try sRGB, Adobe RGB, ColorMatch RGB and others) until you are satisfied.
      Figure : Embedded Profile Mismatch dialog box
      Figure : Missing Profile dialog box
    • Click OK.
  5. From the File menu, select Print with Preview.
    • Select Page Setup.
      • Format for: Select the printer (for example, HP Designjet Z3100ps GP 24in Photo).
      • Paper Size: Select the size of the paper that is currently loaded into the printer.
      • Orientation: Select the orientation of your image on the paper.
      • Click OK.
    • Set the Position and the Scaled Print Size you need.
    • Select the Color Management tab.
      • Print: Select Document.
      • Options, Color Handling: Select Let Photoshop Determine Colors.
      • Options, Printer Profile: Select the right profile for your printer and paper type.
      • Options, Rendering Intent: Select Perceptual.
        Figure : Print dialog box, Color Management tab
    • Click Print.
  6. Choose driver settings.
    • Printer: Select the printer (for example, HP Designjet Z3100ps GP 24in Photo).
    • Select Image Quality from the drop-down menu, then select the Paper Type that is currently loaded into the printer (or Any). Also, select Standard quality options and drag the slider to Quality.
      Figure : Image Quality panel
    • Select Color Options from the drop-down menu.
      • Select Print in Color.
      • Under Color Management, select Application Managed Colors.
        Figure : Color Options panel
    • Click Print.
Print a color photo for an exhibition (Photoshop, PCL driver)
This example uses Adobe Photoshop CS2 under Mac OS X, with the PCL driver. Color management is done by Photoshop.
    • Click OK.
    • Click OK.
      • Click OK.
    • Click Print.
    • Select Paper Type/Quality from the drop-down menu, then select the Paper tab.
      • Paper Type: Select the paper type that is currently loaded into the printer.
      • Quality Options: Select Standard and drag the slider to Quality.
    • Select the Color tab.
    • Click Print.
Print a black-and-white photo for an exhibition (Photoshop, PS driver)
This example uses Adobe Photoshop CS2 under Mac OS X, with the PostScript driver. The color management is done by the printer's internal PostScript RIP.
Application-managed colors could be used in this example, exactly as in the previous example. However, printer-managed colors will be used this time, in order to illustrate both methods of color management.
The recommended approach to creating a black-and-white image is to take a color image and convert it to grayscale in an image editing program such as Photoshop. In this scenario, however, this conversion will take place in the printer. If you want to convert a color image to black-and-white in Photoshop CS2, you have to go through the optional step 5.
    • The paper type should be calibrated with the printer and the print-quality level that you intend to use.
    • Click OK.
    • Click OK.
  5. (Optional) Use Photoshop to convert the image to grayscale. The simple way is to go to the Image menu and select Mode, Grayscale.
    Alternatively, you can go to the Image menu and select Adjustments, Channel Mixer, to choose the percentage contribution of each color channel to the grayscale image, as follows:
    1. Check Monochrome.
    2. Drag any source channel's slider to the left to decrease the channel's contribution to the output channel or to the right to increase it, or enter a value between -200% and +200% in the text box (for example: 30% Red, 59% Green, 11% Blue). Using a negative value inverts the source channel before adding it to the output channel.
    3. Drag the slider or enter a value for the Constant option. This option adds a black or white channel of varying opacity: negative values act as a black channel, positive values act as a white channel.
      Figure : Channel Mixer dialog box
    4. Click OK.
  6. From the File menu, select Print with Preview.
      • Click OK.
      • Options, Color Handling: Select Let Printer Determine Colors.
    • Click Print.
  7. Choose driver settings.
      • Select Print in Grayscale.
        If you experience bronzing with these options.
      • Under Color Management, select Printer Managed Colors, and then select Use Adobe RGB (1998) from the source profile list.
    • Click Print.
Print a black-and-white photo for an exhibition (Photoshop, PCL driver)
This example uses Adobe Photoshop CS2 under Mac OS X, with the PCL driver. The color management is done by the printer.
    • Click OK.
    • Click OK.
    4. Click OK.
      • Click OK.
    • Click Print.
    • Click Print.
Print a digital album (Aperture, PS driver)
This example uses Apple Aperture under Mac OS X, with the PostScript driver. The color management is done by Aperture.
  2. Open Apple Aperture.
  3. If you haven't already created a project for this album, go to the File menu and select New Project, then name the project. Select the new project in the projects menu (on the left), then go to the File menu and select Import, Folders into a Project.
  4. Select the images you want to use, then go to the File menu and select New From Selection, Book.
    • Theme list: Select a theme in the list to see a preview of its design on the right.
    • Book Size popup menu: Select the physical size of the book.
      Figure : Theme list
    • Click Choose Theme, and rename the book album.
  5. If you like, change the page layout and customize it. You can add photo and text boxes, modify the box positions and the text styles.
  6. You can let Aperture place your images into the book automatically (select Autoflow Unplaced Images from the Book Actions menu ), or you can place them manually by drag and drop. Furthermore:
    • You can scale, crop, and pan the image.
    • You can set an image as page background and apply wash.
      Figure : Book layout
  7. Print your book, using the Print button in the Book Layout Editor.
    • Presets Name list: Select your book preset.
    • Select Copies and Pages to print.
    • Paper Size: Select the paper size on which you want to print the job.
    • ColorSync Profile: Select the correct color profile for the printer and paper that you will use.
    • Select Black Point Compensation.
    • Gamma: Because computer displays are illuminated, images displayed on computers tend to look more luminous than when printed. Increasing the Gamma from the default of 1.0 can compensate for this. Usually, a setting 1.1 to 1.2 is adequate.
  8. Click the Printer Settings button.
    • Click Print.
Print a digital album (Aperture, PCL driver)
This example uses Apple Aperture under Mac OS X, with the PCL driver. The color management is done by Aperture.
      Figure : Theme list
    • Click Print.
Proof the output on the monitor (InDesign, PS driver)
This example uses Adobe InDesign CS2 under Mac OS X, with the PostScript driver. Color management is done by the printer.
  2. Open Adobe InDesign CS2.
    • Make sure that the Advanced Mode check box is checked.
    • Working Spaces, CMYK: Select Europe ISO Coated FOGRA27 in Europe, U.S. Web Coated (SWOP) v2 in the USA, or Japan Standard v2 in Japan.
    • Missing Profiles: check Ask When Opening.
    • Conversion Options, Intent: Select Perceptual for RGB images or Relative Colorimetric for CMYK images.
    • Click OK.
  4. From the File menu, select Open to open the document.
  5. Place the images if necessary. From the File menu, select Place; browse the available images and click Open.
  6. From the File menu, select Document Setup and check that all settings are correct for your document.
  7. From the View menu, select Display Performance, High Quality Display.
  8. From the View menu, select Proof Setup, Custom.
    • Profile: Select the profile of the output device you want to proof. A printer profile generally depends on the printer model and paper type. If you don't see the correct profile in the list, you should copy the profile into the /Library/ColorSync/Profiles folder.
    • Display Options (On-Screen), Simulate Paper Color: This affects the display on the monitor only. Check the box if you want to represent the color of the paper on the screen. Otherwise it's assumed to be pure white.
      Figure : Customize Proof Condition dialog box
    • Click OK.
    • Now you can retouch your image and see on the screen how it will look when printed.
  9. From the File menu, select Print.
    • Press the Page Setup button.
      • Format for: Select the printer.
      • Orientation: Select the orientation of your document on the paper.
      • Click OK.
  10. Press the Printer button to change the printer driver settings.
      • Under Color Management, select Printer Managed Colors.
        Figure : Color Options panel, Basic tab
    • Click Print.
  11. Check the Adobe InDesign Print settings.
    • Setup (left-hand menu):
      • Paper Size: Select Defined By Driver.
      • Options: Select whatever scaling option you need.
    • Output (left-hand menu):
      • Color: Select Composite RGB.
    • Color Management (left-hand menu):
      • Options, Color handling: Select Let InDesign Determine Colors.
      • Options, Printer profile: Select the profile of the printer or press you want to proof; it should be the same as selected in the Proof Setup dialog box (U.S. Web Coated (SWOP) v2 in this case).
    • Click Print.
Proof the output on the printer (QuarkXPress, PS driver)
This example uses QuarkXPress 7 under Mac OS X, with the PostScript driver. Color management is done by the printer's internal PostScript RIP.
The aim in this example is to create a concept proof of a press - in this case a Europe ISO Coated FOGRA27 press. QuarkXPress will convert the document and its images to the ISO Coated space and send it to the printer, which will convert it to its final colors emulating such a press. So there are two stages of color conversion involved.
  2. Open QuarkXPress 7.
  3. From the Edit menu, select Color Setups, Source, New, and choose a Name to identify your custom Source Setup.
  4. Select the RGB tab.
    • Solid Colors, Profile: Select Adobe RGB (1998).
    • Solid Colors, Rendering Intent: Select Relative Colorimetric or Perceptual.
    • Pictures, Profile: Select Adobe RGB (1998).
    • Pictures, Rendering Intent: Select Perceptual.
    • Check Color Manage RGB Sources to RGB Destinations.
      Figure : Edit Source Setup, RGB tab
  5. Select the CMYK tab.
    • Solid Colors, Profile: Select Europe ISO Coated FOGRA27 in Europe, U.S. Web Coated (SWOP) v2 in the USA, or Japan Standard v2 in Japan.
    • Solid Colors, Rendering Intent: Select Relative Colorimetric.
    • Pictures, Profile: Select Europe ISO Coated FOGRA27 in Europe, U.S. Web Coated (SWOP) v2 in the USA, or Japan Standard v2 in Japan.
    • Pictures, Rendering Intent: Select Relative Colorimetric.
    • Check Color Manage CMYK Sources to CMYK Destinations.
      Figure : Edit Source Setup, CMYK tab
    • Click OK.
  6. From the Edit menu, select Color Setups, Output, New, and choose a Name to identify your custom Output Setup.
    • Name: Choose a name to identify your custom Output Setup.
    • Mode: Select Composite.
    • Output Options, Model: Select CMYK.
    • Output Options, Profile: Select Europe ISO Coated FOGRA27.
      Figure : Edit Output Setup dialog box
    • Click OK.
  7. From the Edit menu, select Preferences, Color Manager (in the left-hand menu under Print Layout).
    • Check the Black Point Compensation check box.
    • Source Options, Source Setup: Select your custom Source Setup.
    • Soft Proofing, Proof Output: Select your custom Output Setup.
    • Soft Proofing, Rendering Intent: Select Relative Colorimetric.
      Figure : Preferences, Color Manager
    • Click OK.
  8. From the File menu, select Open and browse your project. To insert images, draw a box with the Rectangle Picture Box and insert the image using File, Import Picture.
  9. Select the image, then go to the Item menu and set Preview Resolution to Full Resolution.
  10. From the File menu, select Print.
    • Select the Colors pane from the left-hand menu.
      • Color Options, Mode: Select Composite.
      • Color Options, Setup: Select your custom Output Setup.
        Figure : Print Test dialog box
      • Click OK.
  11. Press the Printer button to change the printer driver settings.
    • Click Print in the driver window.
    • Click Print in the QuarkXPress Print window.
Proof a press using the EFI RIP
  1. Open EFI Designer Edition for HP.
  2. Open the RIP Preferences, and the Color tab will appear by default.
    • Select Proofing as Color output preset.
    • Select the input/emulation CMYK profile for the press you want to emulate. For example, ISOcoated.icc (for Europe), Best_SWOP_Ref_Presssheet_2003.icc (for US). You can find more information about EFI default profiles in Chapter 4.2.2 'Image profiles' of the RIP manual.
    • If you do not find your desired press profile in the list, just add it by selecting the Add Profile button.
    • Press the Advanced button and check the setting Use Embedded Profiles. It will use the profiles included in the image, if any.
    • Choose the paper and print mode you want to use under Media profiles.
    • Click OK to close the Preferences window.
      Figure : Preferences window
  3. You can select any other layout- or printer-dependent settings in the Printer and Layout settings.
  4. Drag and drop the file you want to proof to the RIP queue.
    Figure : Job List window
    Remember the supported formats are: PS level 3, PDF 1.7, EPS, TIFF, JPEG, DCS 2.0, PDF/X1a, PDF/X.
  5. Click Print in the toolbar or in the menu, and that’s it!
