    Fix HP Printer issue on macOS
HP CM8060/CM8050 Color MFP with Edgeline Technology - Device Behavior menu
This menu is also available through the embedded Web server. In the embedded Web server, select the Settings tab, and then select Configure Device from the menu on the left side of the screen. See Use the embedded Web server.
Values that have an asterisk (*) are the factory-default values. Some menu items have no default.
Menu item
Sub-menu item
Sub-menu item
Values
Language
Select the language from the list.
Use this feature to select a different language for control-panel messages. When you select a new language, the keyboard layout might also change.
The language does not change until the control panel returns to the Home screen.
Keyboard Layout
Select a keyboard layout from the list.
You can customize the layout of the virtual keyboard that pops up for editing control-panel information.
Key Press Sound
On*
Off
Use this feature to specify whether you hear a sound when you touch the screen or press buttons on the control panel.
Inactivity Timeout
Type a value between 10 and 300 seconds. The factory default is 60 seconds.
Use this feature to specify the amount of time that elapses from the last activity on the control panel to when the device resets to the default settings. At the end of this time, any users who are signed in to the device are automatically signed out.
Image Transfer Order
Maintain page order
Automate for fastest output*
Use this option to specify the order in which pages are printed.
To print jobs quickly, the default setting is for the device to analyze the job and then to first print the pages that require the most ink. This can result in some pages being printed out of sequence. The output pages will be in the correct order, but if the job requires using different medias from various trays, an image might be printed on the incorrect media type.
Some print functions, such as printing checks, might require the Image Transfer Order option to be set to Maintain page order so that the exact job sequence is used by the device.
Warning/Error Behavior
Clearable Warnings
On
Job*
Use this feature to set the amount of time that a clearable warning appears on the control panel.
Continuable Events
Auto continue (10 seconds)
Press OK to continue*
Use this option to configure the device behavior when the device encounters certain errors.
Jam Recovery
Auto*
Off
On
Use this feature to configure how the device handles pages that are lost during a jam.
Tray Behavior
Use Requested Tray
Exclusively*
First
Use this feature to control how the device handles jobs that have specified a specific input tray.
If you select Exclusively, the device never selects a different tray when the user has indicated that a specific tray should be used, even if that tray is empty.
If you select First, the device pulls paper from another tray if the specified tray is empty.
Long-Grain Paper
Show “Long-Grain” warnings*
Hide “Long-Grain” warnings
Use this feature to show or hide pop-up warnings that appear when a user configures a tray for a long-grain paper type.
Configuring a tray for long-grain paper but loading it with a different type can result in reduced reliability and print quality.
Manually Feed Prompt
Always*
Unless loaded
This feature applies to print jobs. Indicate whether a prompt should appear when the type or size for a job does not match the specified tray and the device pulls from the multipurpose tray instead.
Select Always to show the prompt every time the tray does not match the setting. Select Unless loaded to show the prompt only when the tray is empty.
PS Defer Media
Enabled*
Disabled
Use this feature to choose either the PostScript (PS) or HP paper-handling model.
Use Another Tray
Enabled*
Disabled
Use this feature to turn on or off the control-panel prompt to select another tray when the specified tray is empty.
Size/Type Prompt
Display*
Do not display
Use this feature to control whether the tray configuration message appears whenever a tray is opened or closed.
Duplex Blank Pages
Auto*
Yes
Use this feature to control how the device handles two-sided jobs (duplexing).
Bin/Binding Behavior
Staples Out
Continue*
Stop
Use this option to stop printing if the finisher is out of staples.
Job Offset
On*
Off
Use this option to slightly shift each completed job as they are stacked in the finisher output bin.
Function Separator Mode
Function separator*
Mail box mode
Use this option to set the finisher to operate in separator or mailbox mode.
The mailbox mode setting requires Web JetAdmin.
In mailbox mode, this item specifies the default output bin for each type of job (print, copy, received fax) and updates the default Output Bin dialog selection for the Copy application.
General Printing Behavior
Default Paper Size
Select from the list of paper sizes.
Use this feature to configure the default paper size used for print jobs.
Override A4/Letter
No
Yes*
Use this feature to print on letter-size paper when an A4 job is sent but no A4-size paper is loaded in the device (or to print on A4 paper when a letter-size job is sent but no letter-size paper is loaded). This option will also override A3 with ledger-size paper and ledger with A3-size paper.
Manual Feed
Enabled
Disabled*
When this feature is enabled, the user can select manual feed from the control panel as the paper source for the job.
Edge-to-Edge Override
Enabled
Disabled*
This feature allows the device to print text or images as close as possible to the edge of the paper.
Courier Font
Regular*
Dark
Use this feature to select which version of the Courier font you want to use.
Wide A4
Enabled
Disabled*
Use this feature to change the printable area of A4-size paper. If you enable this option, eighty 10-pitch characters can be printed on a single line of A4 paper.
Print PS Errors
Enabled
Disabled*
Use this feature to select whether a PostScript (PS) error page is printed when the device encounters a PS error.
Print PDF Errors
Enabled
Disabled*
Use this feature to select whether a PDF error page is printed when the device encounters a PDF error.
Personality
Auto*
PCL
PDF
PS
Use this feature to configure the default print language or personality for the device. Normally you should not change the device language. If you change the setting to a specific device language, the device does not automatically switch from one language to another unless specific software commands are sent to it.
PCL
Form Length
Type a value between 5 and 128 lines. The factory default is 60 lines.
PCL is a set of printer commands that Hewlett-Packard developed to provide access to printer features.
Orientation
Portrait*
Landscape
Font Number
Type the font number. The range is between 0 and 999. The factory default is 0.
Use this feature to specify the font number for the user-soft default font using the source that is specified in the Font Source menu item. The device assigns a number to each font and lists it on the PCL font list (available from the Information menu).
Font Source
Internal
USB
Use this feature to specify the location of the fonts for the device to use.
Font Pitch
Type a value between 0.44 and 99.99. The factory default is 10.00.
If Font Source and Font Number indicate a contour font, then use this feature to select a default pitch (for a fixed-spaced font).
Font Point Size
Type a value between 4.00 and 999.75. The factory default is 12.00.
If Font Source and Font Number indicate a contour font, then use this feature to select a default point size (for a proportional-spaced font).
Symbol Set
PC-8
Roman-8
Roman-9
ISO L6
PC-775
Use this feature to select any one of several available symbol sets from the control panel. A symbol set is a unique grouping of all the characters in a font.
Append CR to LF
No*
Yes
Use this feature to configure whether a carriage return (CR) is appended to each line feed (LF) encountered in backwards-compatible PCL jobs (pure text, no job control).
Suppress Blank Pages
No*
Yes
This option is for users who are generating their own PCL, which could include extra form feeds that would cause blank pages to be printed. When Yes is selected, form feeds are ignored if the page is blank.
Media Source Mapping
Standard*
Classic
Use this feature to select and maintain input trays by number when you are not using the device driver, or when the software program has no option for tray selection.
