    Fix HP Printer issue on macOS
HP CM8060/CM8050 Color MFP with Edgeline Technology - Information menu
Use this menu to print information pages and reports that are stored internally on the device.
This menu is also available through the embedded Web server. In the embedded Web server, select the Settings tab, and then select Configure Device from the menu on the left side of the screen. See Use the embedded Web server.
Information menu
Menu item
Sub-menu item
Values
Administration Menu Map
Print
Shows the basic structure of the Administration menu.
Configuration Page
Print
A set of configuration pages that show the current device settings.
Supplies Status Page
The HP logo only appears in front of the supply name when genuine HP supplies are used.
Print
Shows the status of supplies such as cartridges and staples
Fax Reports
Except for Speed Dial List, these items appear only if an analog fax accessory is installed.
Fax Activity Log
Print
Contains a list of the faxes that have been sent from or received by this device.
Fax Call Report
Thumbnail on Report
Auto Print
A detailed report of the last fax operation, either sent or received.
To print a thumbnail image of the first page of the fax on the report, select Thumbnail on Report.
Select from the following options for the Auto Print function.
  • Never auto print
  • Print after any fax job
  • Print after fax send jobs
  • Print after fax receive jobs
  • Print after any fax error
  • Print after send errors only
  • Print after receive errors only
Billing Codes Report
Print
A list of billing codes that have been used for outgoing faxes. This report shows how many sent faxes were billed to each code.
Blocked Fax List
Print
A list of phone numbers that are blocked from sending faxes to this device.
Speed Dial List
Print
Shows the speed dials that have been set up for this device. If you are using LAN or Internet fax instead of the analog fax accessory, this is the only report that appears in this menu.
Usage Page
Print
Shows information about the number of pages that have been printed on each paper type and size.
Current Settings Page
Print
Shows the current Administration menu settings.
Sample Pages/Fonts
Demonstration Page
Print
A demonstration page that provides an example of the print quality.
RGB Samples
Print
A color palette that shows the red, green, and blue (RGB) values for this device. Use this palette to match the color in printed output to an exact color.
CMYK Samples
Print
A color palette that shows the cyan, magenta, yellow, and black (CMYK) values for this device. Use this palette to match the color in printed output to an exact color.
PCL Font List
Print
A list of printer control language (PCL) fonts that are currently available to the device.
PS Font List
Print
A list of PostScript (PS) fonts that are currently available to the device.
File Directory
Print
A directory page that contains information for any mass-storage devices, such as flash drives, memory cards, or hard disks, that are installed in this device.
